Old 08-09-2006, 10:36 AM   #1
bad64nova
91 chevy no start
5.0 No Start With Cluster In Vehicle Remove Cluster Will Start And Run But Will Die When Put In Gear Has New Iac Pcm Map Egr Valve Igntion Coil , Pickup Module Has Left Front Turn Signal On All The Time When Key Is On With Cluster In Vehicle Remove Cluster
Turn Signal Goes Out And Will Start Thanks For The Help
bad64nova is offline   Reply With Quote
Old 08-09-2006, 11:00 AM   #2
Jason915
Re: 91 chevy no start
sounds like a short or a loose ignition switch connection. I would just start a process of elimination by disconnecting and searching for a loose connection and shorts.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 08-09-2006, 12:15 PM   #3
bad64nova
New Switch All Connections Good Have Disconnected All Sensor One By One The Only Way Can Get To Run Is Take Cluster Out Any Other Ideas Thanks
Old 08-09-2006, 05:47 PM   #4
Jonboy
Slots go on anything!
maybe there is a short in the cluster?
1974 Jimmy- 5.3/4L80e/NP241
