Old 08-09-2006, 01:30 PM   #1
davidh
davidh's Avatar
coil sping to leaf sp frame. Same driveshaft?
I'm looking at swapping a 71 leaf spring frame from my 67 coil, I'd get disc brakes, pwr steering and leafs.
Would I use the same driveshaft? Or would I need to modify or change mine?
davidh is offline   Reply With Quote
Old 08-09-2006, 02:14 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: coil sping to leaf sp frame. Same driveshaft?
when I changed my 68 ovr to coils I used the same shaft. I just made sure the pinion yokes both took the same joint first. (look it up at a parts store)
68C15 is offline   Reply With Quote
