08-09-2006, 01:45 PM | #1 |
Diagram for a propotioning valve
Does anyone have a diagram of a proportioning valve for a 72? I removed the large fitting on the rear of the valve and the spring pressure popped out 3 pieces I need to re-assemble it but I'm not quite sure of the order in which to put the parts back in... Any help appreciated!
BTW: It is a disc/drum valve...
78 C10 LWB Super Cheyenne Last edited by 68jimmy; 08-09-2006 at 01:46 PM. |
08-09-2006, 04:57 PM | #2 |
Re: Diagram for a propotioning valve
Ttt
78 C10 LWB Super Cheyenne |
08-09-2006, 10:29 PM | #3 |
Just had one of mine apart a few weeks ago to clean out some gunk and get freed up. Can you post a pic of the parts, can't describe assembly order from memory right now.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 08-09-2006 at 10:29 PM. |
08-10-2006, 09:56 AM | #4 |
Here are the pieces that popped out when I removed the rear fitting... So if you imagine the prop valve is on the exteme left do I have the order of the pieces correct?
Thanks!
08-10-2006, 11:54 AM | #5 |
Sorry - That looks quite a bit different from the one I had apart, since this is a safety related item, I would rather not guess how that one goes together.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
