08-10-2006, 10:13 AM | #1 |
Post Whore
Which cancel cam plunger do I need?
I am putting a van tilt column in my 69 K20 and will likely be using a Grant steering wheel with it.
The cancel cam on the van tilt is missing the plunger and I know there are at least two styles. One is just a metal plunger and the other is a plastic piece, that goes where the metal plunger would be, with a spring on the plastic end then a wire lead that goes out of the plastic piece. Any idea which plunger I should be using? Here's a couple pics of the van tilt's cancel cam. Any suggestions on plunger style I should use or if I should be using a different style cancel cam? As you can see I don't know anything about them
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
08-10-2006, 10:40 AM | #2 |
its all about the +6 inches
Re: Which cancel cam plunger do I need?
you have the right cancel cam. With a grant GT, you'll want the one with a wire.
08-10-2006, 11:10 AM | #3 |
Post Whore
Thanks Andy.
08-10-2006, 12:24 PM | #4 |
Man that's a nice truck!
