Does anyone have a set of rust free seatbelt anchor bolts they would like to sell?Can a person use grade 8 bolts instead of original bolts?
------------------ 1969 chevy 1/2 ton LB 1992 Chevy 1/2 Ext.Cab 1996 Yamaha Virago 750 Central Minnesota
1969 chevy 1/2 ton LB 1992 Chevy 1/2 Ext.Cab 1996 Yamaha Virago 750 Central Minnesota |
go bucks!
the bolts (imo)aren't as critical as the backing plates that would be placed on the bottom-side of your floor pan. you would need to make some to distribute the load over a larger surface area. .125" steel plate available in most machine shops,drill a hole out ,round the corners some,drop your grade 8's through,you're done.
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
its all about the +6 inches
How many bolts you need? You're looking for the factory ones, right? I should have a few laying around here somewhere.
Shoot me an e-mail. addy in signiture. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
Old member
You can by them at parts stores now. NAPA,Advance,Auto zone such as that carry them now.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 71,factory tach,tilt for straight drive,gauges,ac,305 HO TPI with 700-R4 lowered,17" wheels www.geocities.com/chevy71tpi/main.html www.picturetrail.com/Andy4639
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
