08-12-2006, 04:57 PM | #1 |
Frame or Cab...What does the title go to and/or with???
I am trying to figure out the best way for me to do this next
68' SWB, "Frame Off". If I buy a rolling frame does the title go with the frame...or does the title go with the cab? Since it will be a frame off nothing spared, maybe it makes more sense for me to buy a 71' or 72' rolling frame that already has the disc brake front end and then I'd need to find a cab and 68' front clip. I have a new wood floor bed and tailgate sitting here in my office, so don't need a bed. Or.....should I go the other way and find a good 68' SWB complete and sell the bed....and add the 71'-72' disc front end? What is the best way to go? Anyone have experience with this type of situation? Thanks Alex Last edited by ChevyDude; 08-12-2006 at 04:58 PM. |
08-12-2006, 05:01 PM | #2 |
Re: Frame or Cab...What does the title go to and/or with???
cab
08-12-2006, 05:12 PM | #3 |
its all about the +6 inches
it depends on your state.
Some say it MUST match both (cali) some say one or the other. Call your DMV or see there www. site |
08-12-2006, 07:06 PM | #4 |
"Trucks with Class"
Get the title with the matching frame & vin tag. Put the vin tag on any cab you want to use! You will then have a correct, legal, more valuable, matching # truck.
Some people don't care, but their trucks are then pretty limited in what & where they can sell them. It just isn't that hard to get them "right". |
08-12-2006, 07:10 PM | #5 | |
Sounds like solid advise...OK maybe I'll start to look for a rolling 71'-72' frame with the title and vin tag, and see how that search goes! |
08-12-2006, 09:17 PM | #6 |
For me in Cali; The DMV wanted the title and the frame number to match. They said they would make a tag for my cab. The person there told me the cab is just like sheetmetal replacement part.
Dano
'69 Fleet It ain't yours, if you didn't build it! |
08-12-2006, 09:36 PM | #7 |
The LuvShack Garage
I am in the process of selling a Blazer tub, it will have No title or vin
plate, and a Blazer chassis, it Will have a title and vin plate, just like Pickmup said, you can mix and match anything, just check ur state.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 08-12-2006 at 09:36 PM. |
08-12-2006, 10:04 PM | #8 |
So I makes the most sense that the vin plate and title stay with the frame. As stated above the cab is just sheelmetal and can be easily changed as we all know.
Alex |
08-12-2006, 10:27 PM | #9 | |
72 Cheyenne Super 80 Silverado Blazer 2wd |
08-12-2006, 10:30 PM | #10 |
67 is sold
I would say it should go with the cab.
It sounds like very few states compare all three. What does your state do? The odds of it being checked are slim. It is more likely it will be compared to the cab then with your frame. IMO - swapping VIN plates on cabs of cars and trucks is fraud any way you try to polish it... There is a reason that selling the plates on ebay and forums like this is banned |
08-13-2006, 12:03 AM | #11 |
So I found a SWB 68' , that I'm going to look at on Monday...I know where the vin plate in on the cab...where is the "Matching Numbers" found on the frame?
08-13-2006, 12:22 AM | #12 |
on top right behind the stearing box
common sense isn't so common anymore |
08-13-2006, 01:19 AM | #13 |
I looked on mine and I don't see any #'s there??? Your saying drivers side, top of frame, opposite the power steering box and rag joint? I see nothing?
08-13-2006, 06:46 AM | #14 |
In Missouri it's the vin tag with the cab and it is against the law here to alter or change the vin tag. They can actually confiscate your truck if they see the vin has been altered in any way. Check with your state, they are all different.
08-13-2006, 09:06 AM | #15 |
8 vehicles only 4 that run
Dangit, Bobby! I am in the process of taking the cancer trashed body off of a 72 C20 to switch the body off of a 68 C10 onto it. I have the title for the 68, but want the dana 60 w/ rear leafs and front discs frame. I'm not crazy about 8 lugs and 16.5 rims, but that might change later.
95 2500 350 w/ 3.73 72 GMC 1500 SWB stepside 65 Chevy C10 SWB stepside 72 Chevy C10 LWB fleetside |
08-13-2006, 10:23 AM | #16 | |
08-13-2006, 11:03 AM | #17 |
pa only requires a VIN sketch when you get the title... so my cab is my truck, or atleast the plate is...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
08-13-2006, 12:37 PM | #18 |
OK...can someone PLEASE post a pic of the Vin # stamped on the frame. I cannot find any numbers on my 71' other than the Vin Plate rivited to the cab drivers door area.
08-13-2006, 01:19 PM | #19 |
Here's mine on a 1970 Chevrolet. Sorry camera phone sucks but at least you can see exactly where the #'s are at.
1970 custom/10 (was 8-350) long bed factory a/c,power steering, power brakes added front disc brakes from a 72 and rear axles 5 lug 79 chev 1 ton 01 GMC Jimmy |
08-13-2006, 02:53 PM | #20 |
Ok, found the frame stamp. Frame stamp was Z663882 which is the same last seven, letter + numbers on my VIN plate. Thank you for the pic and help! Now I know what to look for.
It is possible there is a 1 before the Z on the frame, but I would have to scrape the paint. I can see all the other numbers and just checked the paper title...everything matches. Last edited by ChevyDude; 08-13-2006 at 02:59 PM. |
08-16-2006, 01:02 AM | #21 |
Some states will give you an "assembled vehicle" title where the frame and cab VINs don't match. I have the same issue -- Using a 1972 cab on my '67 4x4. But changing the VIN plate sounds like asking for trouble. The VIN plate from the '72 will be innacurate, but that's the breaks.
