Old 08-12-2006, 09:19 PM   #1
Als454
P/B Problem
Got my brake system back together, pressure bleed the brakes, my pedal is nice and firm. When I start the engine the pedal goes soft. When I pump the pedal the power booster seems to be leaking air out the rear where the rod from the pedal goes in. Also I notice the engine idle changes when I depress the pedal. Is my booster bad or could it be something else?
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 08-12-2006, 09:38 PM   #2
Sweet72
Sweet72's Avatar
Re: P/B Problem
You guessed correctly, your booster is leaking. Napa has them for our trucks for about 130 bucks.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 08-12-2006, 11:06 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: P/B Problem
Agreed. Don't bother with used ones. it may be good today, but I'll bet a kick in the daddy parts it'll go bad fairly soon.
I lost an engine to a bad booster. A massive vaccume leak on an already lean motor pulling a hill at 4000 RPM = boom.
Old 08-13-2006, 09:47 AM   #4
Als454
Re: P/B Problem
Thanks guys!!!!!!
