Old 08-12-2006, 10:43 PM   #1
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Brake rotor...
What is the thickness on disc brake rotors of the 71-72 variety??? I bought some loaded calipers here a while back and they won't slip over the rotors. The rotors I have are about 1 1/4", the opening between the brake pads are about 1 1/16". Do I have the wrong calipers?? Later, Mark
FuelCellGuy is offline   Reply With Quote
Old 08-12-2006, 10:46 PM   #2
cdowns
cdowns's Avatar
Re: Brake rotor...
take a c-clamp and try pushing the piston all the way into the bore to get the clearance needed
Old 08-13-2006, 11:17 AM   #3
FuelCellGuy
FUEL CELL GURU
Re: Brake rotor...
The loaded calipers are brand new and already bottomed out. I am thinking that maybe these calipers fit GM cars.
Old 08-13-2006, 11:33 AM   #4
crazy longhorn
Fabricate till you "puke"
Re: Brake rotor...
Early 80's pickups (some) had a 1" thick rotor, vs the 1 1/4" rotors on the older trucks. These required different spindles, as well as calipers..... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
