Old 08-13-2006, 01:01 AM   #1
67Mach1
67Mach1's Avatar
Need photo of installed power steering Pump?
I know strange question but I need to see what it looks like, if someone has photos?
Reason: My 70 GMC Sub has had a wobbeling pump and spotty power steering ever since I got it. In getting it ready for inspection it needed to be fixed, So we investigated today and found that there was one bolt broken one stripped and helicoiled and the one attached to the motor mount was about to fall out.
Further investigation revealed that it looks as if the pump either is not the origional one or the lines ahve been swapped over from another truck.
FYI sub has been lowered and converted to front disc brakes so it is possible that the lines came from a donor mid 70 truck too.
Point is I had to do a load of work to get it to fit and bolt back up only to find that the pulleys are not ligned up correctly. If any one has a photo of what the correct pump for a 70 gmc with a 350 looks like< i would appreciate it.
Soon to be selling all but one, or two... Depends on what the Boss has to say.......
67 GMC Shortbed 454 Project
more junk and most of it
is for sale
67Mach1 is offline   Reply With Quote
Old 08-13-2006, 01:30 AM   #2
Rokcrln
Rokcrln's Avatar
Re: Need photo of installed power steering Pump?
Dont know if these will help!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 08-13-2006, 01:31 AM   #3
Rokcrln
Rokcrln's Avatar
and the mount
Old 08-13-2006, 08:46 AM   #4
67Mach1
67Mach1's Avatar
Kevin- that looks exactly like the pump and set up I have with the Two bolts in front. (I had to drill and tap one broken bolt out of the block and the top one was helicoiled already.
They are different on the back bracket. My bracket is much thicker where it bolts to the motor mount. IIRC it has about a 1/2 inch thick mount thickness and it is two pieces sandwiched together, if that makes sense?
unfortuantly no camera so No photos last night. Will try to get some today /Monday.
We couldn't get a bolt back in the rear mount but we did get a stud in there and then mounted the unit on the stud. Which was better than the PO as there was nothing there at all.
Thanks for the Photos.
Thomas
is for sale
Old 08-13-2006, 07:57 PM   #5
JimKshortstep4x4
Kevin,
Nice job on taking the pictures!
Kevin's pump setup is a 71 or 72 with the stamping, (item 5 in the schematic).
The 69 and 70 trucks had a cast item 5 so it would be a lot thicker. Here is the schematic for the 71-72 style pump brackets.
Jim
Old 08-13-2006, 11:53 PM   #6
Rod
I think it's time to mention again that there are three styles of Power Steering pumps for these trucks,less BB stuff which would make 4,..but heres a pic of three that can fit 68-72 typically.
So just getting a pump can still leave you short the correct crank pulley and perhaps water pump pulley.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 08-14-2006, 07:24 AM   #7
67Mach1
67Mach1's Avatar
Your photos make it appear that my pump came from something else and was installed on my truck. The pullys are off, just a slight bit. But from the other post it looks like the bracket is correct, perhaps the pump itself was swapped out.
Thanks for the great photos and information.
Lucky for me the belt is staying on for now.
Might have to search for something else down the line but right now just trying to get it back on the road and pass inspection. What I have done should last( I hope), it was working for some time before I got it.
Thanks.
is for sale
