Old 08-09-2002, 03:45 PM   #1
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
Question I need ideas...please
Ok heres the deal, i have my 67 gmc short-step...its got a 350 w 4-speed, has HEI, K&N filter, Dual exhaust...now what i need are some ideas for some upgrades/mods/power boosters that i can do pretty easily, and for not too much money, can anyone help me out?
thanks
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 08-09-2002, 04:11 PM   #2
diggin69
Southern but in Ohio!!!!
diggin69's Avatar
well if thats all you have, intake,carb,or rejet carb,headers,duel exaust,bigger coil on H.E.I., spark plugs, 8.8 wires,change rear end gears, there is alot you can do best to sit & think of what kind of gain you really want.....then ask what you can do, performance upgrades are endless......
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79
1972 custom-10 half/ton longbed
1980 1/2 ton 4x4 all original 350/350/205 with air
Eaton,Oh
rebelryder@hotmail.com
diggin69 is offline   Reply With Quote
Old 08-09-2002, 05:15 PM   #3
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Not enough info to go on but based on a stock motor. If you want to go fast you can do a camshaft upgrade, (nitrous ground), a good steel crank, bolt on some air flow research heads and a 750 dual pump Holley, then bolt on your nitrous setup and whallaa= your fast. Is it as easy as that? No, but to go fast you need money and this nitrous is the cheapest go fast add-on there is. But you need to make some upgrades to run it. One of my friends runs a 302 small block ford in a 84 stang and he's running 10.17's at 130mph with a 200 shot of nitrous. You just have to build your motor to take it.........JB
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
