Old 08-09-2002, 04:51 PM   #1
buckshot
buckshot's Avatar
Question 85 2wd burb on 80 1ton 4x4 frame
can you put an 85 burb on an 80 1 ton truck frame?is the wheelbase the same or is there a difference?i know you'll probably have to fab up the body mounts but i didn't know if there was a wheelbase difference.any help would be appreciated.buckshot
buckshot is offline   Reply With Quote
Old 08-11-2002, 10:57 AM   #2
Mudder
Mudder's Avatar
You need
to do lots of measuring and comparing. I havent heard of anyone doing this but I'm sure someone has. Wheel base is easy to measure. Compare!
Mudder is offline   Reply With Quote
Old 08-11-2002, 09:20 PM   #3
buckshot
buckshot's Avatar
Thumbs up
Mudder67,thanks for the help.i appreciate it.also,what year frame did you say you used?i have a 60 model truck i thought about dropping on a 78 4x4 frame(if i can buy it cheap)
Old 08-12-2002, 01:23 AM   #4
Mudder
Mudder's Avatar
I used
a 77 chassis that I had abused for several years. I switched the 67 body on this chassis back in 1986. The truck was used and abused regularly.
Old 08-12-2002, 10:08 AM   #5
6869704X4
Ive heard that the longbed trucks and burbs are the same frame. But like Mudder said only way to be sure is to compare.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 08-12-2002, 11:39 PM   #6
DINS 1
DINS 1's Avatar
I think the wheel base is different on the burbs and pickups from 73 & up. also the rear parts of the frame is longer than the pickup. not possitive on the 73 and up burbs and trucks. You will just have to do some research. exhaust books list wheel base for each model of truck.
Wade
"DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project
2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 08-12-2002, 11:46 PM   #7
buckshot
buckshot's Avatar
Thumbs up Thanks
Mudder67,6869704x4,and DINS 1 - thanks for all the help.i appreciate it.buckshot.
