Old 08-14-2006, 12:30 PM   #1
RunTMCfan
RunTMCfan's Avatar
Shifting noise when I stop and then go???
When I firmly press the brakes at say 10mph everything stops great. But I feel a shifting somewhere under the driver seat and towards the the fender well. It shifts again when I take off.
Is this a clue to the ultimate demise of my Rockers???
Rob
"RunTMCfan"
RunTMCfan is offline   Reply With Quote
Old 08-14-2006, 11:23 PM   #2
tom71
what happened to flint mi
tom71's Avatar
Re: Shifting noise when I stop and then go???
run i would jack it up with jack stands under both the axles , start it up and put your foot firmly on the brake and then put it into drive let the brake out and slightly press the accelerator and then press the brake again and try to feel if it is still shifting , you could have a buddy look around down there while doing this to see if anything seems irregular. check your motor mounts and trans mounts too as well as spring perches . but really its hard to tell with out driving the vehicle 1st hand
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 08-15-2006, 12:12 PM   #3
cdowns
cdowns's Avatar
i'd check the cab mounts could be rusted or broken or the rubber mounts have rotted to nothing causing the cab to shift
Old 08-15-2006, 01:09 PM   #4
RunTMCfan
RunTMCfan's Avatar
Motor is tight. I could be the cab mounts. I have not done the fronts yet.
Rob
"RunTMCfan"
Old 08-16-2006, 10:04 PM   #5
tom71
tom71's Avatar
oh i saw one of your posts about body mounts i thought you did all of them so i ruled those out .
97 fiance mobile
Old 08-17-2006, 07:21 AM   #6
Huck
Huck's Avatar
HOld your foot hard on the brake while the truck is in gear, then rev it enough to torque the engine and trans. Do this a couple of times and the problem will become obvious when the thing comes apart!hehehehehe--Don't do this in a garage or while parked behind your local police car. I suspect motor mounts, trans mount or spring mount issue. Was a common problem way back when.
Huck is offline   Reply With Quote
Old 08-17-2006, 10:08 PM   #7
RunTMCfan
RunTMCfan's Avatar
Thanks guys. Good advice huck.
Rob
"RunTMCfan"
Old 08-18-2006, 06:13 PM   #8
Chris_T
Sounds a lot like mine at one point - a bad trans mount that eventially led to a loose crossmember
Chris_T is offline   Reply With Quote
Old 08-21-2006, 04:15 PM   #9
Mark Mazzanti
Check your upper control arm shims. I have seen many of come out and have that exact problem
Mark Mazzanti is offline   Reply With Quote
