Old 08-14-2006, 11:48 PM   #1
Clos'84TX
Foom, foom, foom!
Clos'84TX's Avatar
Help! Idling out of control
Well, this has been an on going problem. It started with my old Carb.(Q-Jet) and since then I installed an new (remanufactured one) with an automatic choke. I hooked all my vaccum lines/linkage/ springs..... I even warmed up the truck as the direction said for idle adjustment. I adjusted the idle all the way out to where the shouldn't be any idle.. but no normal idle...
Is there some where else on my linkage or throttle cable that may be sticking?
Please help.
I'll post a picture tomorrow, thanks..
- Dan
84' LWB C10 // 2.5" from collector back. duel Turbo
Mufflers // 350 w/ TH350
long Headers//3.73 rearend gears
Future Mods
3/4 suspension drop
Clos'84TX is offline   Reply With Quote
Old 08-15-2006, 09:55 AM   #2
mhicks
mhicks's Avatar
Re: Help! Idling out of control
Checked your timing? Can you pull the throttle lever on the carb to make it idle down?
mhicks is offline   Reply With Quote
Old 09-11-2006, 10:40 AM   #3
Clos'84TX
Foom, foom, foom!
Clos'84TX's Avatar
Update, got my truck idling down..replaced the throttle return spring. adjust --adjusted and adjusted some more. My hot/Running idle screw is completly turned out..
Just a question for any automatic choke specialist out there..which way should I adjust the, automatic choke for a shorter time at start-up (less choking, pull off the throttle?
- Dan
Future Mods
3/4 suspension drop
