67-72 Addict!
Replacing cab mounts?
Is it possible to replace the cab mounts without removing the carpet "entirely" and the seat and the belts???. I would like to only pull the front carpet back enough to get to the bolts and do the same for the back mounts. Has anybody done it without ripping everything out to access the bolts?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
![]() Join Date: Nov 2004
Re: Replacing cab mounts?
The back bolts are underneath the gas tank enclosed with metal tabs pushed down around them. If your truck is not too rusty and the bolts will turn easily you can reuse the nuts (that's what I did), otherwise, I think you have to pull the gas tank to get to them. The front ones will have a small spot weld holding it in place. I would get the nuts loose/off before breaking the spot weld loose. This can be easy or tricky. On my truck I was able to "break" the PS weld with a wratchet and bar. On the DS no such luck, I had to break it with a hammer and chisel (can't get a grinder down in the floor divet without accidentally cutting the floor up.)
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-15-2006 at 09:43 AM. |
67-72 Addict!
Thanks 67- Maybe there is hope!
