Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 08-15-2006, 12:28 PM   #1
LILREDGMC
FS 4WD Front and Rear Axle
I have the front and rear differentials, 3:08 non posi from a 77 or 78 4wd Chevrolet pickup. I am not the 4wd expert so, you may correct me if you see a flaw in this post. The front has warn hubs, but the transfer case is 203, so I take it they are add on's. Fluid was good in both cases, 6 lug 1/2 ton, appears that rotors were fairly new, surface rust from sitting but little deep corrosion. Pads were near new as well. Did not pull rear drums yet for inspection.
Front is a 10 bolt, rear is a 12 bolt. Plan to remove spring bolts and leave springs intact with differentials.
There was a local interest in the rear, but don't know if he is real or not.
Located near Pittsburgh. May put on pallets and band to ship. Might consider assisting with delivery.
$100 each $150 for the pair.
Transfer case is available as well as 350 turbo transmission. I have no knowledge of internal condition.
Truck was driveable until motor let go, transmission fluid is clean, did not drop pan yet. Trans and transfer $50 each ORO
LILREDGMC
You may post replies on site or
Email to Boyerlk@aol.com
LILREDGMC is offline   Reply With Quote
Old 08-17-2006, 08:35 AM   #2
LILREDGMC
Re: FS 4WD Front and Rear Axle
Front and rear differential have been sold.
Transmisssion, transfer case, still available.
Will post tilt column and rear slider on new post.
LILREDGMC
Old 08-21-2006, 12:19 PM   #3
LILREDGMC
73-80 Tilt Automatic Steering Column complete $100 plus the ride
73-87 Rear slider window w/o rubber. Not sure about how it is or was supposed to lock. $40 plus the ride
May be able to deliver along I-70 west to Indiana, or I-80 east to Danville PA from time to time.
Pics available. Email makes it easier. I will revisit the posting method later today.
LILREDGMC
