Old 08-15-2006, 12:44 PM   #1
LILREDGMC
FS - Rolling Chassis -
I have three rolling chassis for sale.
1969 Chevrolet 3/4 ton 2wd, swing arms with coils,, overload leafs, from Nevada. It has been here in PA for a few years, stripped cab and bed for other use last fall. Frame has no damage, has light surface rust and could be an ideal use for restoration of another truck. Driveline still in it, 350/462 4spd, Eaton rear ratio unknown, not checked yet. Priced without engine and transmission.
1969 or 70 Chevrolet or GMC, 2wd 1/2 ton with leaf springs. Does have the cross member before the rear differential removed. Light surface rust, again, could be used in restoration of another truck. Was an Ohio truck. 12 Bolt rear, drum brake front, pan not yet removed, ratio unknown.
1971-72 Chevrolet GMC 1/2 ton 2wd, swing arm frame. Swing arms were sold, frame is solid from Colorado, has light surface rust, full disc front end, rear end still under truck, but no swing arms. No damage to frame or suspension. 12 bolt rear, expect it to be open, 3:08, cover not removed yet.
These could all be used for restoration of some other truck, i.e. blast, paint and transfer sheet metal etc.
I will get some pics to post hopefully late today.
Price $200 ORO each.
Hate to haul to scrap yard but can't keep forever.
LILREDGMC
LILREDGMC is offline   Reply With Quote
Old 08-15-2006, 09:24 PM   #2
lloyd k
lloyd k's Avatar
Re: FS - Rolling Chassis -
very interested in the 69 leaf frame, do you have any pictures?
67 swb gmc,big block cadillac powered,400 turbo,2.73 ratio and disc brakes-basically a frankenstein of many parts-
lloyd k is offline   Reply With Quote
Old 08-15-2006, 10:11 PM   #3
LILREDGMC
I will go through the pics I have and post one. I can forward all via email if you send me an email.
LILREDGMC
Old 08-15-2006, 10:18 PM   #4
lloyd k
lloyd k's Avatar
gmc500cid@wowway.com
