08-16-2006, 01:30 AM | #1 |
12 bolt dimensions??
anyone have measurements from a 12 bolt from alot of these trucks? outside of drum to outside of drum?? and also what spline are these things usually??
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
08-16-2006, 05:45 PM | #2 |
Re: 12 bolt dimensions??
08-16-2006, 07:46 PM | #3 |
Fabricate till you "puke"
The axles are 30 spline.....beyond that I cant help much. I do know that the 67-69, or mid 70? axles were narrower than the later pcs. 5 lug went in 71, & those diffs should be the same lenght as the 73-82 ,12 bolt. Once again, sorry I caint help with numbers..... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-16-2006, 10:12 PM | #4 |
no brain no headache
I just went and measured mine for you and its 58" from flange to flange. This is on a 1970 12 bolt, the earlier ones a narrower by i think an inch.
edit mine is bare and gutted so i DONT have the drums on sorry
1996 GMC Sierra z71 1970 SWB 2wd (project) Last edited by 70c10swb; 08-16-2006 at 10:13 PM. |
