Old 08-16-2006, 08:30 AM   #1
stynchrr
stynchrr's Avatar
Parts truck Questions
I am getting an 87 1 ton reg cab chevy truck with a 350 and and auto trans. The motor and trans is the reason i am getting the truck but I was wondering is there any thing else i can use off the truck for my 72 2wd swb before i scrap it? Sway bar, power steering, brake booster, .......
Also any body have an idea if there is a turbo 350 or 400 in there. I am going to find out for sure later today but i was just wondering if anybody knew what was standard.
stynchrr is offline   Reply With Quote
Old 08-16-2006, 11:17 AM   #2
Americanrider
Re: Parts truck Questions
My guess is Th400. If the truck has a hydro-boost braking system save it. The 14 bolt in the rear should be the same as our 4x4 trucks, 40.5 inches between the center of the spring pads and is worth 100-150 depending on ratio/condition. Also save the one piece driveline.
Americanrider is offline   Reply With Quote
Old 08-16-2006, 07:04 PM   #3
Roachgod
Roachgod's Avatar
Is a 79 1 ton 2wd rear the same also? I think I may be better off parting it out when I gank the 454 annd the hydroboost and maybe a fuel tank for my 70.Then I could sell the low mileage granny low 4spd with new wrecker clutch, rear end, 8 lug aluminum slots, and scrap metal.
1970 custom/10 (was 8-350)
long bed
factory a/c,power steering, power brakes
added front disc brakes from a 72 and rear axles 5 lug
79 chev 1 ton
01 GMC Jimmy
Roachgod is offline   Reply With Quote
Old 08-16-2006, 10:02 PM   #4
Americanrider
Not sure. I know that 3/4 ton 14BFF are 42.5 or there abouts between the centers of the spring pads. They are cheap here but it takes some work to grind them off and re-set and then do the shock mounts.
Old 08-17-2006, 08:04 AM   #5
stynchrr
stynchrr's Avatar
Well it a turbo 400. I guess i am going to check the tank and grab the hydro boost, power steering, sway bar, and drive shaft. My brother wants the rear. Is there anything else I should be looking at?
