Junior Member
67 GMC grill
I know this has probably been asked before but I couldn't find it in the search. What will it take to put a 67 GMC grill on my 72 GMC. Is the rad support different?
72 GMC 3/4 ton Custom Camper 5.3 ltr 4l60e 72 Chevy Blazer 4x4 327 4spd 70 Olds Cutlass supreme 455 4spd m21 |
![]() Join Date: Jun 2002
Re: 67 GMC grill
Fenny, the radiator support will work but the top bar for a 67 will not work with the hood from a 72.
You have 2 options: use the 67 grill & topbar with a 67-68 hood and hoodlatch (hood latches are different). You would have to remove the moulding on the fenders and fill the holes. It would look similiar to the pic attached. or You can remove the 67 grill topbar, install the 72 topbar and use the 72 hood and hood latch. I like option 1 but that's just me... Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Last edited by raggedjim; 08-16-2006 at 12:48 PM. |
