Old 08-16-2006, 09:06 PM   #1
Daubs
Daubs's Avatar
Remove Rust stains on driveway...
Some are from fert, others from PB blaster. What is best way to remove rust stains from my driveway?
Thanks, D.
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 08-16-2006, 09:23 PM   #2
dougs69c10
dougs69c10's Avatar
Re: Remove Rust stains on driveway...
super clean and a pressure washer
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end
dougs69c10 is offline   Reply With Quote
Old 08-16-2006, 09:24 PM   #3
Daubs
Daubs's Avatar
Is that a brand of cleaner? Never heard of it? Where to buy?
Old 08-16-2006, 09:54 PM   #4
shelby987
shelby987's Avatar
its a little backyard mechanic, but I have used soft scrub on my cars in the past, it took the stains out without any problems, and while none of my cars had a show quality paint job, I never noticed any damage to the paint.
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 08-16-2006, 10:41 PM   #5
dougs69c10
dougs69c10's Avatar
yes, its in a big purple jug, either in a gallon or 2.5 gallon jugs, any auto part store, hell prob even walmart now carries it
Old 08-16-2006, 10:49 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Here it is- www.superclean.com
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-16-2006, 11:41 PM   #7
Daubs
Daubs's Avatar
Thanks!
Old 08-18-2006, 07:38 AM   #8
Will this work on brick chimneys?
Old 08-18-2006, 09:55 AM   #9
big blue 72
muriatic acid works best for brick
big blue 72 is offline   Reply With Quote
Old 08-18-2006, 10:04 AM   #10
junkyardjohn
junkyardjohn's Avatar
I JUST MOVED. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-18-2006, 10:39 AM   #11
Shane
Shane's Avatar
Simple Green and a pressure washer will work too.
Heck, you get a big enough pressure washer and you won't need any cleaner.
Shane is offline   Reply With Quote
Old 08-18-2006, 11:35 AM   #12
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
The only thing I have found that works is "new concrete". Mine is all spotted with POR.
PICKMUP is offline   Reply With Quote
Old 08-18-2006, 12:19 PM   #13
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
If the driveway is concrete, muriatic acid is the bomb. BUT, it etches the concrete, so if yours is the slick smooth finish, it will be rough afterwards. The acid is GREAT for eating rust off of metal as it is, so it should take the rust off of the concrete as well.
On a side note, if you use the acid to take rust off of a part, don't let it sit too long in the acid or it will eat the whole part. also, you have to wash and scrub the part good afterwards to neutralize the acid, but then you have to dry it quick to prevent flash rust. IF the part is small enough, stick it in the kitchen oven on high for a few minutes.
*Thread Hijack Finished*
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline   Reply With Quote
Old 08-19-2006, 03:20 PM   #14
roj2323
i'd try something like dish soap and a brush followed by a power washer first. it sounds weird but i found that dish soap really works well. just pour some over the oil stain and let it sit for an hour or two scrub it then let it sit for 15 or so then power wash.
if you go with the meriatic acid route make sure you dilute it alot! 2 cups to 5 gallons of water should do the trick. also this is really a 2 person thing, one to scrub with a broom like brush and another to man the garden hose. gloves rubber boots and a sightly windy day would be a good thing as well as this stuff is nasty. meriatic acid will burn you and or kill you if you don't pay attention. throw the brush away when you are done as it's going to fall apart anyway. experiment with the time you let it sit before you scrub it may take as little as 1 miniute. if there are stoborn spots remember you can allways come back and spot clean.
ondrew
roj2323 is offline   Reply With Quote
Old 08-20-2006, 10:52 AM   #15
ClemsonChevy
Yeah, I forgot to mention the fumes...... They are nasty. Cleans your sinuses in 0.000001 second. You can get respirators that filter out muriatic acid (named specificly), but unless you are working with it alot, just stay upwind and hold your breath when you are really close. And always have water close by to rinse YOU off if you splash it on you.
95 2500 350 w/ 3.73
