sufficiently talented fool
![]() Join Date: Jun 2006
Any mods for 3/5 drop springs?
I am thinking about purchasing 3/5 drop springs for my 72 c10. Are there any mods required to install these?
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
Keepin an eye out
Re: Any mods for 3/5 drop springs?
Not really, just be carefull, under some pressure removing the old, new go in easy. You will want to get a alignment upon completion.
I guess I should add you will want to get drop shocks and rear shock relocaters as well as a adjustabe panhard bar or track bar kit.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 Last edited by boraxman; 08-17-2006 at 12:28 AM. |
Thanks boraxman!!! I knew about the shocks, but forgot about the panhard bar. As long as I don't have to c-notch or anything i'll be fine.
Does a 3-5 drop make the truck ride rough? I thought I recalled someone here mentioning the truck rode "weird" after using a 3-5, but I could be wrong too. Thought I might as well ask in case there are any problems.
"You can take the man out of PA, but you can't take PA out of the man" |
3" for the front may be a little too much. You may be riding on your bumpstops a good bit. You may want to look into some spindles instead. Just my .02
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
Senior Moment
![]() Join Date: Mar 2002
We had 3" springs in the front of my Sons 71 LWB and it rode like crap. We changed to 2 1/2 spindels and a 1" spring and got the ride hieght we wanted and a nice ride. Its down 4 " in the rear with springs plus 2 " blocks for a total of 6. You can feel the differance in ride from front to rear, the front is nice the rear is ruff.
Good Luck
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Low & Slow
Go with spindles and 1.5 - 2" springs..
I had to shave my bumpstops with 2" springs in the front.. I wouldn't run the 3" springs.. It will ride on the stops..aka bad ride.. I'm running a 4.5/6 drop with my lwb.. No notch
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
mini truck racer
Anyone have shock absorber suggestions for lowered trucks ?
Low & Slow
I'm running kyb's early classic has in their drop kits.
