Old 08-17-2006, 12:45 PM   #1
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
1981 c/10 trans
i got an 81 chevy c/10 and i am trying to figure out how to the the bell housing bolts out the easiest . do you have to let the trans mount go and let the trans hang down or what . having a hard time getting at the bolts . help please .
1964 CHEVY 1/2 C/10 FLEET
1981 CHEVY 1/2 C/10 FLEET
1995 DODGE 1500 V6 FLEET
EAST
http://www.flickr.com/photos/bigasspimp/?saved=1
BIGPIMP is offline   Reply With Quote
Old 08-17-2006, 01:47 PM   #2
75sierraclassic
75sierraclassic's Avatar
Re: 1981 c/10 trans
When I've done it, I always drop the tranny mount and pull out driveshaft to let the tranny come down a bit. Be carefull that it doesn't drop too much cause the motor will also tilt back and the distributor can hit the firewall. Once its tilted down, I use an impact and a long extension, about 2-3 ft to undo the bolts. With it tilted down you should be able to access all the bolts.
75sierraclassic is offline   Reply With Quote
Old 08-17-2006, 01:54 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Re: 1981 c/10 trans
I use a 3/8 socket and ratchet, with two long extensions and a6" extension between the socket and the ratchet. I can position myself at the rear crossmember and reach the bolts on the bell housing, with ease. I also have taken the top bolts out of the bell housing by sitting on top of the motor and reaching down past the distributor. I pulled the motor out of the truck in less than 3 hours that day.
piecesparts is offline   Reply With Quote
Old 08-17-2006, 07:01 PM   #4
Prerunner1982
Prerunner1982's Avatar
Re: 1981 c/10 trans
last time I did this I sat on the engine and took off all that I could, the rest were accessed from below without dropping the cross member. Engine was pulled, trans left in the truck.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 08-17-2006, 07:15 PM   #5
82c10
needin' money
Re: 1981 c/10 trans
when i pulled mine out, i got the top 2 while i was sitting on top of the motor, and the bottom 4 i got out after i put a jack under the trans and took the crossmember out(driveshaft,tq bolts,etc) and then just dropped it down by lowering the jack
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 08-17-2006, 07:58 PM   #6
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
Re: 1981 c/10 trans
thanks guys for all the help .kinda thought what you guys suggested . this is the best place ever .
EAST
Old 08-18-2006, 08:42 AM   #7
Jonboy
Slots go on anything!
Re: 1981 c/10 trans
a 9/16" swivel socket will do wonders there. I use that, and as many extensions as it takes to loosen everything when you are sitting behind the crossmember. the 9/16" swivel socket will be 10 bucks well spent.
1974 Jimmy- 5.3/4L80e/NP241
