Rolled on Paint Club
![]() Join Date: Jan 2006
Front brake drum ?
I had to grind 3 rivets off of each of my front drums to get them off. Does this mean that I had the original 36 year old drums on the truck and the PO's have been pulling the hub off the spindle to change shoes??
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
Re: Front brake drum ?
what's unusual about that??
I guess that is what I was wondering. Is it unusual or fairly typical?
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. Last edited by Bob D; 08-17-2006 at 04:44 PM. |
its all about the +6 inches
I've seen it quite a bit.
The replacement ones at the parts store suck... you'd be better off locating old originals that can still be turned. |
Who's got steelies?
![]() Join Date: Feb 2006
It seems that was GM's way of making you inspect or at least look at the wheel bearings. I think I remember the service manual saying the front wheelbearings should be inspected and serviced at the same time the shoes are replaced.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
back in the day oldtimers would rather go spend half a day in junkyards searching for originals that were usable instead of grinnding the rivets for "replacement drums" or in my fathers case send me
#7 | |
So instead of getting the made in china junk drums, send cdowns to the junk yard, he'll get them for you. ![]() Last edited by Longhorn Man; 08-19-2006 at 12:59 AM. |
I am a Referee of life.
Probably just a P.O. who did his own brakes or had a quality shop do it.If the shoes are always replaced before they wear to the rivets then they wont need turning.I have always pulled the wheel bearings when doing a brake job so I could repack them so they may have been pulled hub and drum together so the wheel bearings could be serviced.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Thanks for all the replies, Guys.
I am reusing these drums since they are in great shape. The rears are a different story. One drum was noticeably lighter than the other and appeared to have been ground too thin. So, I have one drum, all shoes, spring kits and 4 cylinders on order. Bob
