Old 08-18-2006, 02:07 AM   #1
GREASEMONKEY72
GREASEMONKEY72's Avatar
Question quadrajunk i mean jet
my problem with it is mostly when its fully warmed up it take for ever to start unless someone holds the choke open so i took the choke butterfly off and it starts everytime nomatter the temp however i have to kick the idle down by hand now and i was wondering if anyone else had the same problem and what you did to fix it and if i rebuild the carb will that fix it any info is appreciated thanks in advanced
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 08-18-2006, 07:18 AM   #2
Re: quadrajunk i mean jet
They are one of the best carbs made,IMO.Sounds like you have a sticky choke and maybe sticky linkage.I assume you`ve already checked for interference and ofcourse lubed it.Alot of things can happen in 30 or more years to affect the linkage,as far as bendind,etc.I wonder what we`ll say about all these Edelbrock carbs in 30 years.
Old 08-18-2006, 08:00 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
they have been mking for about that long now. they were originally a Carter AFB. even factory installed on a few muscle cars IIRC
it sounds like a stuck or mis-adjusted choke stat
68C15 is offline   Reply With Quote
Old 08-18-2006, 12:07 PM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
lube the linkage, put a little stronger return spring on the carb.
sneakysnake is offline   Reply With Quote
Old 08-18-2006, 12:12 PM   #5
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
I had an old buick with a quadrajet. What I found with it, is that once it is warm and you turn if off, the choke stays open to allow you to start it with no problems. BUT, if you tap the gas pedal, the choke butterfly would close. So, if you are tapping the gas before you try to start it after the engine is warmed up, you may be doing the same thing that mine was doing. I had to learn not to tap the gas (like we usually have to do to start it cold) once the engine is warm.
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline   Reply With Quote
Old 08-18-2006, 08:28 PM   #6
You`re only supposed to tap the pedal once,and only once,to set the choke when engine is cold.
Old 08-19-2006, 03:08 AM   #7
GREASEMONKEY72
when its cold it starts fine its when its hot that i takes forever to start peddle tapping or not which i dont touch the pedal unless i have to, but would rebuilding the carb still help in the overall performence? cause its pretty damn filthy..lol
-steven
Alte Seele S.S.
Old 08-19-2006, 12:48 PM   #8
RSRXION
RSRXION's Avatar
I'm with K on this one ! The fact that it's filthy is also a clue. A sticky choke is going to be at least part of the problem.
These are indeed outstanding quality carbs when they are working properly. But like anything else, when it's wrong.... IT'S REALLY WRONG ! Most people overlook the metering wells when they rebuild them. Apply a thin layer of epoxy or JB-Weld to the exterior of the bottom of the wells and make sure the existing welch plugs don't leak. This is what usually causes them to flood or run rich. As they age the factory sealant dries out and it leaks unmetered raw fuel into the intake through these holes.
The "bog" can be removed by adjusting the accelerator pump stroke and adjusting the rate on the secondary metering rods.
As a matter of trivia ... What other non GM auto manufacturer used the venerable Quadrajet as a factory installed 4 barrel in a performance application ? I'll give you a hint.............it wasn't AMC.
Any ideas ? Dean
"They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Ben Franklin
RSRXION is offline   Reply With Quote
Old 08-19-2006, 01:00 PM   #9
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
Was it Jeep, or were they already AMC?
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 08-19-2006, 01:56 PM   #10
RSRXION
RSRXION's Avatar
Nope not Jeep.............. next ? Makes , models , years and engine size please. Another hint................ not a pickup or SUV.
Old 08-20-2006, 07:05 AM   #11
crusher311
crusher311's Avatar
um now idea but i can tell you i love my quad thay are the hardest to tune right but when tuned right the best performers by far you can get a rebuilt one for 150 from csk rebuild by holley and thay dont do a bad job of it either. i would rebuild or at least pull it off and give it one hell of a cleaning as a quad that is not tuned right can get very dirty in side i had mine on for two months and it was cloging up i had to pull it and clean then i had to try to tune it a secound time it has been 8 months since and i have not had a problem but i was haveing the same problem you were and cleaning it took care of me. a quad if you replace it the only problem the holley rebuilt has is the return spring is way to strong and it will couse the carb to leak after a few months i found out after my truck started to smell like fuel hehehe flame on.
crusher311 is offline   Reply With Quote
Old 08-20-2006, 08:33 AM   #12
jacobs
jacobs's Avatar
Any ideas ? Dean
Fix Or Repair Daily (FORD)
jacobs is offline   Reply With Quote
Old 08-20-2006, 09:41 AM   #13
RSRXION
RSRXION's Avatar
Is Ford your guess ? If so ....you're right ! So now , what years and what cars with which engines ?
Old 08-20-2006, 09:48 AM   #14
crusher311
crusher311's Avatar
ok i have to step in here on the fix or repair daily my 72 ford has been in the famaly since it was new. and it is the only truck i have that has not broken yet.
my 68 gmc is always broken my ford not once it still has the orig belts on it. no car company has made a perfect car or truck but to single out specif one is not cool becouse my ford is the one that takes me to the store to get all the parts for my gmc. hell even my 57 dodge has let me down but the ford running strong since 1972. i just like the sound my gmc makes better
Old 08-20-2006, 09:53 AM   #15
crusher311
crusher311's Avatar
on a ferther note i have two 72 fords the secound has only had two problems and it was electrical wires break over time red and blue fords white top blue bottem dodge and my baby a red 68 gmc i have had many other trucks to
Old 08-20-2006, 10:23 AM   #16
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is a website that may help you on the rebuild if not then it has a lot of good info.
http://www.4wheelnoffroad.com/qjet.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-20-2006, 11:27 AM   #17
jacobs
jacobs's Avatar
For all you Ferd lovers there is "First On Race Day"
Old 08-20-2006, 11:40 AM   #18
jacobs
jacobs's Avatar
It was used only on the 428 Cobra Jet Engine. Ford used it for only one year and as I recall it was either 1968 or 1969.
By the way, GM wasn't the only manufacturer of the Qjet. Carter made a some for GM although they are fairly rare. My 70 c/10 came from the factory with a Carter Qjet.
Old 08-20-2006, 11:58 AM   #19
RSRXION
RSRXION's Avatar
Man are you close ! Close enough that I'll give you another hint. Ok , we know that it's Ford , used very briefly and in very limited production from 1970-71 model years and in two body styles but only one engine configuration. Now , next guess ?
Old 08-20-2006, 12:41 PM   #20
jacobs
jacobs's Avatar
I'd say the Fairlane and the Mustang.
If it was 1970 and 1971, it would have to be the 429 instead of the 428.
Old 08-20-2006, 07:01 PM   #21
RSRXION
RSRXION's Avatar
PERFECT ! It was used only on the 1970 & 71 Torinos with the 429 Cobra Jet and on the 1971 Mustangs with the 429 Cobra Jet . Of course it was also available on the Mercury sister cars of Montegos and Cougars. Nicely done !
Old 08-20-2006, 07:26 PM   #22
classicgm
classicgm's Avatar
Hey, I have a bunch of q-jet tuning documents and links at http://www.florida4x4.com/tech/quadrajet . Hope that helps
classicgm is offline   Reply With Quote
Old 08-20-2006, 09:31 PM   #23
GREASEMONKEY72
thanks for all the help everyone i havnt done anything to mine yet cause i havnt had time to yet but when i do i will let you guys know what happens
-steven
Alte Seele S.S.
