08-18-2006, 03:34 AM | #1 |
Long or short water pump?
Sorry if this has been asked before. I have a 72 Chevy short bed 4x4 that I just bought a new crate engine for. It's the 290HP GM Performance motor. I'm needing to buy a water pump for it, but I don't know if I need the short or the long one. I plan to re-use the brackets and pulleys off the old motor, so I want to make sure I get the right pump.
Anybody know which one I need to get? ETA: I don't have the old motor out of the truck yet, which is why I can't take the pump up to the parts store with me.
1972 Chevy SWB 4x4 Last edited by KOOLmike; 08-18-2006 at 03:35 AM. |
08-18-2006, 05:04 AM | #2 |
4 eyed fever
Re: Long or short water pump?
Look down and see if the inside edge of your WP is in line with the outside edge of your timing cover. If so it's a short, if there is 3/4" or so gap then it's a long one. I believe this is accurate, but not 100% sure. All 3 of the original motors I've got use the short, and the one with an 86 with serp belt uses the longer one.
1971 GMC 2500 4x4 1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto. 4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!! |
08-18-2006, 05:09 AM | #3 |
Cool, man. I kinda figured it'd be the short one, as they seem to be the most popular on the older motors. Thanks for the reply!
1972 Chevy SWB 4x4 |
08-18-2006, 06:36 AM | #4 |
The stock pump was short. All trucks used short pumps until '73.
Tim |
08-18-2006, 09:54 AM | #5 |
Senior Moment
You'll like that Motor, we have one in my Sons 71 LWB in front of a Muncie 4 speed. Lots of fun to drive, great power for what it is.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
08-18-2006, 12:02 PM | #6 |
It's a catastrophic success.
pics
08-18-2006, 12:04 PM | #7 |
Straight jacket required
How about a '69 396 BBC??
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." |
08-18-2006, 07:55 PM | #8 | |
1970 custom/10 (was 8-350) long bed factory a/c,power steering, power brakes added front disc brakes from a 72 and rear axles 5 lug 79 chev 1 ton 01 GMC Jimmy |
08-19-2006, 12:19 AM | #9 | |
And it turned out the pump I needed was the long one. The current motor must not be the original.
08-19-2006, 07:44 AM | #10 |
The LuvShack Garage
The only way I know on a SBC is this, Short = Drivers side Alt, Long = Passenger side Alt
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
08-19-2006, 07:15 PM | #11 | |
08-20-2006, 05:44 AM | #12 |
short shaft was the most comin one found but thay also had the long shaft in some parts are cheaper for the long shaft and easyer to find. in all types the long shaft was more often found in heavy duty applications becouse it moved more coolant then a short shaft could ever hope toi have a short shaft in mine and it is a pain becouse all the pullies i have are from a long shaft it has been a pain but i have them all lined up after 6 months of tinkering. i wasnt going to spend 60 bucks a pully or 100 bucks for a long shaft to fix the problem but yes long shaft is better anyways
08-20-2006, 05:48 AM | #13 |
ohhh yes and a corection i had pullies long shaft but all my brackets were short shaft but long shafts are better plus more performance options for the long shafts
08-20-2006, 12:30 PM | #14 |
67-72 Addict!
My truck has the lwp and the passenger side alternator.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
