Old 08-09-2002, 10:48 PM   #1
racedvl
racedvl's Avatar
Question Is it possible to......... HEI question.
I have 2 computer controlled advance HEI's in my garage. Can I convert them to a conventional HEI? Thanks.
racedvl is offline   Reply With Quote
Old 08-09-2002, 10:49 PM   #2
brad69C-10
I used to do these, by changing the module over to the old style......works the best.
69 C-10 Pro Street...........red on black...........big block and a lot of go fast stuff under the hood
Still in progress ...........
brad69C-10 is offline   Reply With Quote
Old 08-09-2002, 10:50 PM   #3
frost89434
frost89434's Avatar
I may be wrong but I don't think you can.
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 08-09-2002, 10:52 PM   #4
brad69C-10
well, maybe I didn't then..............I was taking the ones from my 87 trucks, with the 2 seperate plugs on them and converting them to the older style with the one plug to the cap......
Old 08-09-2002, 10:52 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I think the only thing they can bu used for it to make a primer tool out of them.
Old 08-09-2002, 11:23 PM   #6
Beast388
Suburbans RULE!
Beast388's Avatar
Depending on what year and model HEI you have, some don't even have mechanical or vacuum advance.....that was all controlled by the computer.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 08-10-2002, 08:07 AM   #7
racedvl
racedvl's Avatar
Beast388, that's what they are. There is no vacuum advance.
Old 08-10-2002, 10:25 AM   #8
Beast388
Suburbans RULE!
Beast388's Avatar
I would bet that they cannot be converted then. Older HEI's are easy to come by....so I would go that route.
--Ben
71 GMC Suburban 4X4
The "Beast"
