08-18-2006, 09:58 PM | #1 |
How to remove a cab? front end already removed.
I am about to pull the cab on a 69 chevy truck. What am I in for? no seats in cab and no front end on truck. What wrenches, ie sizes, will I need and are there any good tips to removing it.
Will I be able to lift it with one other guy or should I have a few others? If so how many? IIRC there are four bolts that hold the cab on the truck right? Thanks, Thomas
Soon to be selling all but one, or two... Depends on what the Boss has to say....... 67 GMC Shortbed 454 Project more junk and most of it is for sale Last edited by 67Mach1; 08-18-2006 at 10:12 PM. Reason: clarity |
08-18-2006, 10:21 PM | #2 |
sufficiently talented fool
Re: Help Removing a cab?
There are 4 bolts. 2 go in from underneath at the back of the cab. The other 2 are in the front floorboards. The rear 2 will come right out. The front 2 you will need to hold a wrench on one side while turning the other. I used 4 people to lift my cab and move it very easily. My cab was empty ( no doors, glass, wiring, etc. I believe the rear bolts were 5/8 and the fronts were either 13/16 or 7/8. Here is a pic of what my cab looked like when we removed it.
Attachment 212896
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board Last edited by centsless; 10-04-2007 at 08:43 PM. |
08-18-2006, 10:54 PM | #3 |
Tool Addiction=Money Shortage
MAKE SURE YOU HAVE ENOUGH PEOPLE!
I was lucky I Didnt get hurt last year I was parting out a 2wd 67 small window alone and thought I could just pull the cab off with the engine hoist. The cab lifted off the frame fine but as soon as i tried to move it the hoist and cab tipped over just about squashing me. BTW it wrecked my rust free small window cab Hope you have better luck. |
08-18-2006, 11:08 PM | #4 |
Rolled on Paint Club
I removed my cab single handed with only a bottle jack and some scrap lumber. Raised it up off of the frame with the jack, one end at a time, and placed 2 planks under it. Then slid it off onto the ground. The rockers were a little bent up but I didnt care since I was going to replace them anyway.
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
08-19-2006, 12:47 AM | #5 |
its all about the +6 inches
A stripped cab weighs right at 500 pounds... work acordingly.
08-19-2006, 02:02 AM | #6 |
I took my cab off myself using planks. It can be done safely if planned and done slowly. Also a cab could be taken off quite easily with 4 or 5 guys, that is probly the safest way.
1968 GMC 910 -305 v8 -TH350 -3.42 open rear end -in a few hundred pieces (hope I can put it all back together!) |
08-20-2006, 07:55 AM | #7 |
wow cool info as i am also going to be removeing my cab but not all the way off i am only removeing it so i can weld in a new front floor support i will be lifting it up tilting it back and laying it across some 2x6 planks i just need to find four or five guys to do it for me hehehehe i pay with beer. any takers hehehe?
08-20-2006, 11:48 AM | #8 |
laying it on it's back isn't a good idea. Even if you protect the back wall from damage, the firewall is so heavy it can distort the door opening. If you were to make a brace from the hinges to the striker, it'll help, but the posability of damage is still there. Esp if you have rotted rockers.
08-20-2006, 12:24 PM | #9 |
Junior Member
heres a link for plans to make a cab dolly (67-72) that you flip over with out damaging the cab.http://www.bumpandgrindgarage.com/1213226.html
