08-19-2006, 02:40 PM | #1 |
292/700r4 combo?
Has anyone tried this combo in a 4x4?I want to use the 292 in a 4x4 and wondering what trans to use for an overdrive.I plan to pull a gooseneck trailer but not to heavy.any suggestions?
1968 Custom 10 SWB 1970 2wd Blazer 350/400 1972 K20 292/350 |
08-20-2006, 04:39 AM | #2 |
Re: 292/700r4 combo?
The 292 should bolt up to the 700R4. I have heard the 200R4 is beefier than the 700R4 and still has an overdrive. But I have the SM 465 4-speed behind my L6. So I'm no expert on turbo-hydramatics. Good luck.
08-26-2006, 09:41 AM | #3 |
I`m thinking to use a 292 in the`71 shortbed I just got.I may go manual(already a 3spd)with a NV4500.Or,just use a 4spd manual if I decide not to build it for much traveling.I`d like to hear what becomes of your 292/700r4 idea.
08-28-2006, 06:42 AM | #4 |
Sounds like a great combo for a daily driver, just not sure about towing in overdrive with an inline 6.
Seems like it would always be in third when loaded...dunno. |
09-16-2006, 10:26 PM | #5 |
I think it would be a good combo, just make sure you don't have to high of gearing. I prefer at least 3.73 but 4.10 to me would be better. I build mine so you can tow in 4th and if as you say you are not towing to heavy you should be fine. And make sure the cable is (set) right, I use the word set cause there is no adjusting them they are either right or wrong. And don't use a stall convertor, not good for towing. And be sure the lockup is working correctly for long trans life. And a proper size external cooler plumbed in after the radiator is essential as well. Good luck with your decision.
98 Neon 97 Grand Prix GT 02 Grand Prix 40th Anniv. 86 GMC 5.0 77 Olds 98 6.6 REAL AMERICANS, DRIVE AMERICAN |
09-17-2006, 11:46 PM | #6 |
For any type of --even somewhat-- towing, you may want to consider a turbo 400 with a gear vendor. Even with my vast years of transmission building, the 700 just doesn't seem up to the task in my suburban. In my 69 GMC 1 ton, I put in a gear vendor. No issues with reliability now.
09-18-2006, 05:19 AM | #7 |
Does the gear vendor have overdrive?
09-18-2006, 05:30 AM | #8 |
Designated A-hole!
The gear vendor is an overdrive unit (or underdrive depending on how you install it) that mounts in place of the tailshaft on your tranny.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
09-18-2006, 09:24 PM | #9 |
09-19-2006, 05:09 AM | #10 |
Interesting. Thanks.
