08-19-2006, 03:47 PM | #1 |
How smooth do they roll down the road?
ok..
i just spent 6 hours removing the drive shafts cross member and trans..ALL ON MY BACK 69 c-20 350 engine th400 trans LWB replaced the flex plate, converter, front pump seal, all new bolts, reinstalled every thing... i am happy to say it's a heck of a lot smoother..there was a problem with the flex plate or converter. but it's not perfect the drive shaft has been balanced, new u-joints, center bearing, with a 3/4 ton 36 year old truck is this the way they were??? am i expecting to much? i bought good stuff.. next is the brakes hopefully for the last time Last edited by rage'nrat638; 07-12-2007 at 07:02 AM. |
08-19-2006, 05:16 PM | #2 |
Re: How smooth do they roll down the road?
hows your tires wheels and allignment?
common sense isn't so common anymore |
08-19-2006, 05:43 PM | #3 |
Fabricate till you "puke"
Do you pick up a vibe on the hyway at a certain speed, or does it feel RPM related?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-19-2006, 06:17 PM | #4 |
trailing arm panhard bushings/ axel &pinion bearings/ rearend lube been checked or changed in 36years/ engine tranny mounts
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 08-19-2006 at 06:19 PM. |
