Active Member
![]() Join Date: Dec 2002
Location: West TN (Memphis area) now. East TN (my favorite place to live).
Rust Mort
I wanted to see what the Rust Mort product would actually do. So I went to a paint store and bought a quart for $20.00. According to the paint store, use Rust Mort then prime and paint.
I used the Rust Mort on my 62 truck that was setting in the weeds. I was skeptical when I got the product. The product looks like mouth wash. I used a paint brush to apply the Rust Mort. Rust Mort does not need to be mixed. It can be used right out of the bottle. I put the Rust mort on Friday after work. When I checked it today, I could tell a big difference. I am a believer now. Here is the link to the before and after photos. http://fredbrooks.photosite.com/Album7/
BigFredTN 70 chevy stepside 350 with some goodies inside, turbo 400. 69 Chevy long wheel base. Dad bought new in 1970 62 Chevy Impala 98 GMC Yukon 1970 Ford Mustang Fastback I know its a Ford. |
Restoration Desperation
Re: Rust Mort
Do you prep or just paint? Seems flakey like it needs sanding, or does that screw up the rust mort? Never used it but curious.
RD |
Re: Rust Mort
I think you need to remove as much loose stuff as you can before you apply it. It's great for battery box areas and tight places. I'm using it to treat my '70 GMC's small problem areas.
Re: Rust Mort
hmmmm is it a rust inhibitor or is it the stuff that turn rust to its iron counter part if it is then i would also like to try some i use oxpho right now but it is very acidic and hurts the drive way if it hits it but it is also a very good product that does its job
Active Member
Re: Rust Mort
I did not do any prep. Just put Rust Mort on the rust. I might try sanding some of the white stuff before I prime and paint.
