Old 08-20-2006, 01:30 PM   #1
Schralper
Schralper's Avatar
New Driveshaft, feedback wanted!
Ok, gettin a new 2 pc driveshaft made, 1350 ujoints for my 68 w/Turbo400/12b.
1st: trans yoke - should I go w/ a bolt on ujoint yoke or a press fit yoke ?
2nd: center bearing support - poly but original style, bolts parallel to shaft, or newer style bolts perpendicular to shaft. I know I'll need an adapter to mount that one.
Schralper is offline   Reply With Quote
Old 08-20-2006, 08:46 PM   #2
MoBikeRider
MoBikeRider's Avatar
Re: New Driveshaft, feedback wanted!
Is it lowered any? I had a 70 chev long bed that was slammed the ghetto way and it kept breaking the carrier bearing mount. Actually splitting the case the the bearing went in. So after 2 of those. I found one thats made of what I think was aluminum and he said thats what all the lowriders with hydros run on there cars so they won'e break. Put that in and never had a problem again. It was about 200 bucks though. Don't know if that helps any but just thought I would throw that out there.
Nitrous is like a hot girl with STD's. You want to hit it but you're afraid of the consequences!!!!
MoBikeRider is offline   Reply With Quote
Old 08-20-2006, 10:35 PM   #3
Schralper
Schralper's Avatar
It's a longbed, 2.5" dropped spindles and partial coil cut in front, so 3.5" drop there. Coil cut for 1" drop and 2" blocks in rear, so there's 3".
Currently, mild L-82 vette motor for HP.
Getting some serious HP soon, so before I start breaking parts.........
Current driveshaft has seen its fair share of abuse.
Old 08-21-2006, 02:24 AM   #4
junkyardjohn
junkyardjohn's Avatar
I Built A True 500 Hp Big Block /t-400 Short Fleet Truck, It Was Lowerd About The Same Amount As Your's, & My Drive Line Guy Convinced To Go With A 2 Piece. He Was Right. I Regularly Thrashed That Truck For Years, An It Had A Possi 12 Bolt, Line Lock & A Set Of Big Tires. I'd Never Be Afraid To Use Em On A Street Truck. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
