![]() Join Date: May 2006
Wood Bed in '72 GMC Jimmy
Here's my current mods and updates:
![]() ![]() ![]() ![]() ![]() If I can download the rest of my camera I can send more if you want!! Jim
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-20-2006 at 05:56 PM. |
Big Block
Re: Wood Bed in '72 GMC Jimmy
Did you remove the steel floor? I can see the wheeltubs are mounted on top of the wood floor. Did you use some kind of sealant between the wood and the wheeltubs?
Yeah I took out the steel in 5" sections, what a PITA! I redesigned a lot to get it to fit so I could mount the wheelhouses on top. The last crossmember is out of a '73 and up because it has a ledge on it that just happens to be the same thickness of the wood, I wanted steel at the end of the bed for wear purposes. The first crossmember,after the step, is out of a truck, we had to notch it to put a body mount in it! Jim
Yes, I used dum-dum under all the wood where the steel meets it
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-20-2006 at 05:58 PM. |
THey make kits that go over steel floors as well, and they are removeable. saw it on TRUCKS....
I'm afraid my steel floor wasn't in that good of shape, ended up replacing all crossmembers, I'm working on the last one now. It's the thick one that holds your seat belts and goes between the wheelhouses. Jim
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Looks good. I like it. Are you going to be using a back seat?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#7 | |
More Pics: ![]() ![]() ![]() ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-21-2006 at 06:07 AM. |
![]() Join Date: Jan 2001
thats a nice mod (and i dont usually like anything but original) and a
great way to deal with the rust issues. it must not be to easy other wise i would have seen it done more. Nice
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) |
Great idea and well done.It makes alot of sense,on thepracticle side.Looks fantastic,on the....looks fantastic side.
FNG to resto/mod world!
Would really like to see more pics of the rear floor _ looks awesome! Also, what did you use to coat the front floor area? Is that Lizard skin or bedliner or ?
71 GMC Jimmy - under construction 75 GMC K25 Sierra Grande - under deconstruction 92 Chevy K2500 ECSB - sold 04 Nissan Titan ECSB Off Road - sold & missed 13 Ford F-150 Ecoboost (work truck) - sold 16 Ford F-150 Ecoboost (work truck) ![]() |
The LuvShack Garage
Cool concept, may have to consider that in the Roadster project
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Big Block
I forgot to metion, it looks great. Could we see more pictures of the wood floor? Please!
#13 | |
As for the wheel houses, I thought I would have to section them, but I didn't. On the inner fender it has a crease that I had to bend around. I made a slice at the proper height and rebent the flange on the wheel house, and slotted the mounting screw holes, The hard part was in the front corners, I had to route them out, about a 1/2 day on each one. It does look original, as I to am a fanatic about originality. Sorry but I can't bring it to Slatington this weekend, I just couldn't get it done in time! Thanks for the compliments Jim
#14 |
It was Herculiner, real old can, I couln't get all the particles in suspension, so I did 2 coats. Once you put the lid back on the can that's it, it solidifies in the can, no reusing it! Pretty tough stuff, I'll let you know how it holds up. I thought you guys would be tired of seeing pics. It might take awhile, as I just got the camera last night and I'm not to good at it, some of the pics are large. Thanks for the comps. Jim
#15 |
Thanks.... really like your truck, is that Med. Olive Green? Jim
#16 |
Would look good all exposed, brings your eye to the interior. My mistake was cutting the boards separately, if I did it again I would measure and cut them all to same lenght, you can't see it, but I know its there. Oh well, everyone has 20/20 hindsight! Jim
#17 |
You'll have to wait on the pics. as I can't figure out how to download to the server. Worked yesterday. I have 14 pics. of the bed alone! Jim
OK Here ya go: ![]() ![]() ![]() ![]() ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-22-2006 at 06:34 AM. |
#18 |
Back in the sticks
That is really nice! I thought about doing the same thing, but my steel floor is so nice, I decided not to. How about doing a FAQ on it so Krue can post it? Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#19 |
Active Member
That floor looks awesome! Im planning to do the same in the back of my 69 Burban. IT has plywood back there now. So it wont be nearly as much work as yours.
#20 | |
#21 |
Designated A-hole!
A FAQ is a "how to" thread telling (w/pics preferred of course
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#22 |
So is there any help with this "FAQ" or am I on my own. Do you post it up like a thread? Any further questions, who do I address them to. Sounds like work, do people really want this information? Jim
PS Am I allowed to use company names of my suppliers?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-26-2006 at 06:38 PM. |
#23 |
[QUOTE=Rydn2L0w;1790777]That floor looks awesome! Im planning to do the same in the back of my 69 Burban. IT has plywood back there now. So it wont be nearly as much work as yours.[/QUOTE
Maybe you could post up some pics, I am not aware of what a sub. floor looks like. Is it just a longer blazer floor with more crossmembers? Any help on what it looks like would be great! Jim
#24 | |
Designated A-hole!
For inspiration here is a list of almost all our FAQ's http://67-72chevytrucks.com/vboard/s...d.php?t=157669 Here is one I did (a long time ago) for an example. http://67-72chevytrucks.com/vboard/s...32#post1332032
#25 |
Thanks Krue, will you clean up my grammer as well? Jim
