08-20-2006, 06:42 PM | #1 |
No right brake light
I don't have right brake or turn signal lights. Checked at the fire wall plug and do not have any power there. Is there another plug between the firewall and the turn signal switch on the column. Really don't want to get into the column. All the left side is fine, and the frount right is fine. Any help would be appreciated. Thanks Steve
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2. |
08-20-2006, 07:02 PM | #2 |
Re: No right brake light
im with ya but i have everything BUT the right rear brake light i know we have a plug back on the frame by tailgate
08-20-2006, 07:39 PM | #3 |
its all about the +6 inches
if you have nothing at the firewall, then it is probably going to be the turn signal.
08-20-2006, 09:44 PM | #4 |
OK went out and lookedat it again. Found another plugin leaving the stearing column and lo and behold but a wire had pulled out from a stakon from when I installed the cadillac steering column. Stuck it back in and recrimped put the two back together and behold lit there be lights. Thanks Steve
