driving is in my blood
more axle clearence on a 98
I flipped the axle on my 98 x-cab and used a western chassie c-notch. With the stock urathane bumpstop that came with the c-notch I had 1-2.5" of travel. Even after cutting down the bumpstop as much as I could I only have 3-4". I hit the stops on hard speedbumps. How do I get more travel?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Seņor Member
Re: more axle clearence on a 98
There's no shortcut here. If you're hitting, you either raise the truck or you clearance what's hitting.
i did a flip kit on my 96 from belltech but i bought mine used but it came with an air ride setup that bolted to the back portion to the notch well with shackles,hanger and 2 leafs left im glad i got that because when i air it out it hits the bottom of the bed floor but i have to cut the rib for more clearance but when i did just 2 leafs i would bottom out so i went about bought me some air shocks and that kind helped some
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
