Old 08-20-2006, 10:38 PM   #1
67c-10Texas
TH400 under small hump floor
Will a TH400 fit under a "standard" floor (small hump floor? I am using 80's era front suspension with the correct V8 motor mounts.
any help would be great
thanks
67c-10Texas is offline   Reply With Quote
Old 08-20-2006, 10:42 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: TH400 under small hump floor
small block or inline, yes. That's how it woulda come from the factory.
With a big block, it woulda had a high hump. It'll fit if you have good cab mounts, but IMO, NOT a good idea. GM didn't throw the high hump on there just to do it. They did it for a reason.
Old 08-21-2006, 02:57 PM   #3
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Go ahead and put the th400 under the low floor...it will clear just fine. If it didn't you can just cut the floor and bolt in a high tunnel, but I am sure it will clear with no problem. I run that setup with old cab mounts and no problem.
PICKMUP is online now   Reply With Quote
Old 08-21-2006, 06:12 PM   #4
junkyardjohn
junkyardjohn's Avatar
It'll Fit. I've Done It Without A Problem. Not A Whole Lot Of Clearance But It Never Touched Under Any Circumstances. I Probably Got More Heat From The Tranny Inside The Cab, But I Always Run A Tranny Cooler & A Trans. Temp Gage & It Never Got Hot. J0hn
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-21-2006, 08:35 PM   #5
qksilver
It will fit but as mentioned above the cab will be hotter because there isn't as much air flow, plus, make sure all your mounts are in good shape.
qksilver is offline   Reply With Quote
Old 08-21-2006, 09:12 PM   #6
67Mach1
67Mach1's Avatar
So a 71 long bed with a 402 and th400 has a high hump? Good thing I have not trashed the truck yet. Going to take that sucker out next time I go home. Almost trashed it last weekend. Good think i didnt.
T
Soon to be selling all but one, or two... Depends on what the Boss has to say.......
67 GMC Shortbed 454 Project
more junk and most of it
is for sale
67Mach1 is offline   Reply With Quote
Old 08-22-2006, 12:55 AM   #7
69-350
Oil trash and damn proud of it
69-350's Avatar
going along these lines, I've got a 71 cab that had a 350/automatic stuffed under it, I was wondering if a 4speed on a 350 will work? (obviously cutting for the shifter, and with new body mounts) Or do I have to hack the whole tranny hump out and put a removable one in?
Mark
1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift
1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze
2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons
Some of my pics http://s107.photobucket.com/albums/m294/69-350/
69-350 is offline   Reply With Quote
Old 08-22-2006, 05:28 AM   #8
Longhorn Man
What kind of 4 speed?
Old 08-22-2006, 08:05 AM   #9
A NewProcess 4spd will require the high-hump,for sure.
Old 08-22-2006, 09:48 AM   #10
69-350
69-350's Avatar
just the stock 4 speed that came in a 69 (isn't that a NP21 or something?)
Mark
Old 08-22-2006, 09:58 AM   #11
junkyardjohn
Originally Posted by 67Mach1 View Post
So a 71 long bed with a 402 and th400 has a high hump? Good thing I have not trashed the truck yet. Going to take that sucker out next time I go home. Almost trashed it last weekend. Good think i didnt.T
NOT ONLY THAT A FACTORY B/B WITH AN AUTO WILL HAVE A TALL HUMP WITHOUT ANY HOLES IN IT. THIS MAKES IT WORTH ABOUT TWICE AS MUCH. I'VE SEEN EM GO FROM $30 TO $50 DEPENDING ON THE CONDITION & HOW BAD SOMEONE WANTS IT. JOHN
junkyardjohn
DON'T RENT U-HAUL
