Drive swap info
Hey guys,
![]() ![]() How about even a chevy shortbed pickup? Would it bolt up with some simple fabrication. Belive me I now that when it comes to fabbing on any project its never simple, but this is not my first project that I would need someone else to do all the work. ![]()
Long live SLIM ------------------ At least try to buy American ![]() |
Location: vacaville ca, because it as far from indy as i can be
Re: Drive swap info
its a lot easier to go from 2wd to 4wd. you will need to get the 2wd steering box and susp. you will need to drill out the holes on the side of the frame but the ones on the bottom should be there.
a shortbed frame is still 10"+ longer wheel base. |
Re: Drive swap info
So I shouldnt buy a 2wd blazer and just switch the new body to the used frame with the entire drivetrain?
