gummed up
![]() helping a friend eyeman |
C10 now is a GMC
Re: gummed up
If there is no holes in the gas tank, you can has it cleaned out at a radiator shop. But if it has alot of pin holes, it's best to either get a good used one at bone yard, or buy a new one a for a hundred bucks.
Also check to see if the bottom section of the fuel sending unit in the tank is clogged, you can probably clean it out with some solvent, or maybe carb cleaner. If the little metal strap is broke, you can get a new one for I think $30. David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
Re: gummed up
Once you have the tank boiled out, POR15 makes an excellent product for coating the inside of the tank & preventing it from ever having rust again. Google them & check out their web site. I've used a lot of their products with amaizing results.
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com |
Prestige member Old Farts Club
Re: gummed up
If you want the cheap route get the 3 part eastwood kit and let it soak for a long time. Don't forget the fuel pump and carb too
Hey sombodys gotta do it! ![]() |
