Newbie truck Rebuilder!
I need help on how to remove the window from the door of my 1964 GMC. I have everything else off, and all the screws removed, but cannot figure out how to remove the glass and the mechanism.
Any help would be appreciated.....
"Old Blue" 1964 GMC Fleetside in pieces 350 TPI with 700R4 tranny now installed( well kinda propped in place until the tranny crossmember is bolted in ![]() 1995 Toyota 4runner , 197,000 miles and going... ![]() 2007 Honda Odyssey Van (Wifes car) ![]() ![]() |
Re: Window disassembly
did you take the vent windows mechanism out?? Without that piece you will never be able to remove the windows...
Nope, I haven't even looked at taking the vent window out. I will look at that tonight...after that, how does the window attach to the mechanism?
Chad
it is on rollers.....roll towards the front of the door and then the front roller will roll off and then roll the rear towards the rear and it will then roll off and then you can pull the window out....
Got it! It does help taking out the vent window...you would have thought I would realize that!!!
![]() anyway, it will be fun putting it all back together.... ![]() Thanks for the help guys! ![]()
back together in reverse order....good luck...
