Old 08-10-2002, 11:37 AM   #1
Lumpy
2 tons of fun
Lumpy's Avatar
Question 3 or 4 core radiator?
Hello,
Right now I have a 2 core in my 67. Will a 4 core fit right in or do you need special brackets for it to fit? Will a 3 core drop right in? Thanks.........Lumpy
67 Chevy,Short/Fleet,350,Saginaw 4-Speed,Lowered 4x2,small window,P/S,Edelbrock Intake/Carb,HEI,Gear Drive,Crane Cam 274H
Three Rivers, Ca
Pics at: http://www.cardomain.com/id/lumpy454
Lumpy is offline   Reply With Quote
Old 08-10-2002, 12:13 PM   #2
Beast388
Suburbans RULE!
Beast388's Avatar
This may or may not answer your question.....my truck originally had a 3 core and when I installed a 4 core I had to replace the top brackets only. The brackets are fairly cheap.....around $10 if I remember right.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 08-10-2002, 12:24 PM   #3
imdarren
imdarren's Avatar
I think the brackets are diffrent. I tried to upgrade the radiator in my 72 GMC Automatic trans. from a 2 core to a 4. Didn't fit on the bottom, even with larger 4 core brackets on the top. The brackets on the bottom of your 67 will need to be drilled out (they are sort of spot welded in) and a wider set installed if you wish to install a 4 core.
You should be able to drop in a 3 core no problem.
You don't really need a 4 core anyways unless you live in Arazona, have AC, and tow a trailer.
You could have the parts house get you a 4 core. Just tell them up front that it may not fit, and you may need to bring it back and exchange it for a 3 core.
The part that frustrated me was the 4 core was only somthing like $20 more or somthing, and it wouldn't fit!
Good luck!
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 08-10-2002, 12:46 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
2 and 3 core radiator supports are the same. 4 core supports are larger. We have both sizes in stock along with the pads. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-10-2002, 01:21 PM   #5
Mudder
Mudder's Avatar
i changed
from a 3 to a 4 core and there was no difference in the temp by the guage.
Mudder is offline   Reply With Quote
