Old 08-21-2006, 08:11 PM   #1
75Chevy90Kawi
the green machine
75Chevy90Kawi's Avatar
PIC REQUEST - dropped w/stock wheels
i'm gonna drop my truck either 2/4 or 3/5 this winter fall, and am hoping to put on refurbished stock, or near stock wheels ( http://67-72chevytrucks.com/vboard/s...55#post1787155 ). any help with pictures?
1975 Silverado - 450 horse crate 383 stroker, 20" Centerlines, Flowmaster exhaust, Hooker headers, full MSD ignition & more...
2003 Suzuki TL1000R
1985 Kawasaki JS550 hull - project ski - WILL have - 650, footholds, custom paint, 4* bars, bilge setup, and more...
My pictures
75Chevy90Kawi is offline   Reply With Quote
Old 08-21-2006, 08:55 PM   #2
1974gmc
In Progress
1974gmc's Avatar
Re: PIC REQUEST - dropped w/stock wheels
this is roughly 3/5 drop, cut coils in front and flip in the rear.
steel wheels and caps, 235/75 15's
1993 Chevrolet K2500 454 4L80E
1974 GMC 1/2t 2wd Stepside 305 auto *sold*
1985 Ford Mustang GT 5.0 5spd
1974gmc is offline   Reply With Quote
Old 08-22-2006, 01:30 AM   #3
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
psst...
Go with at least 4-6 drop.
Here's an old pic of your ps'ed truck with around a 4-6 drop.
Add some steelies or smoothies like babyblue's ps'ed truck.
'Retro' off the dealership floor.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 08-22-2006, 03:27 AM   #4
75Chevy90Kawi
the green machine
hhmm.... those smoothies ARE mighty fine lookin... i also like the idea of the wheels being original though. i'm hoping to do a sort of "custom/classic" thing. i would like to shave the handles, and i DEFINATELY need new mirrors, and perhaps shave the handle on the tailgate, all to make it look just a little more smooth, but then i think with the stock wheels (maybe widened in rear? again, cool idea...) and original paint, and a done up but still original looking interior.
and yep, i've still got that pic saved on my computer too... its definately something i'll be keeping for reference...
2003 Suzuki TL1000R
My pictures
Old 08-22-2006, 09:30 AM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Here is mine (2.5/4) with stock rally wheels.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-23-2006, 12:31 PM   #6
boatpuller
boatpuller's Avatar
just a little heads up..i wanted to use stock rally's when i lowered mine.it's a five, seven drop.my a arms rubbed even after grinding the lip.research on the forum showed some get away with it,but i didn't.ended up biting the bullet and getting 17in wheels,and glad i did.
boatpuller is offline   Reply With Quote
Old 08-23-2006, 01:27 PM   #7
Slonaker
Slonaker's Avatar
I used 2.5" Western Chassis drop spindles with 8" Rally wheels. I had no clearance problems, and did not have to do any grinding to make them fit.
Slonaker
Stock '01 Silverado
Old 08-23-2006, 01:31 PM   #8
75Chevy90Kawi
the green machine
boatpuller - i'm not exactly a "pro" with suspension, would this still be a problem (possibly) with a lesser drop? i dont plan on going down to 5/7
2003 Suzuki TL1000R
My pictures
Old 08-23-2006, 02:15 PM   #9
boxrodz
boxrodz's Avatar
I think boatpuller is referring to the 3" drop spindles. Some have a slight clearance problem between the lip (or gutter) of the LCA and the rim. How much to grind depends on the diameter and backspacing of the rim. As Slon reported, those that use the 2 1/2" spindles don't have this issue. BTW, you could always step up to a 17" rally or smoothie. Although, I'm not sure anyone offers a truck rally in 17".
BTW, a 8" front and 10" rear wheel setup would look nice.
boxRODz
Old 08-23-2006, 02:16 PM   #10
Slonaker
Slonaker's Avatar
The best way to get your drop is from spindles because they do not affect suspension travel or geometry. My recommendation is to lower it first with spindles, then use drop springs if you want additional drop.
If you go with a stock wheel less than 8" wide, it might interfere with a 2.5" drop spindle, and definitely will with a 3" drop spindle.
I would suggest (but I am biased) that you go with an 8" Rally wheel in the front with 2.5" Western Chassis spindles. I have zero problems with that combo. You could go with 8" or 10" (aftermarket) Rallys on the back since you said in the other thread you want a wide wheel.
If you plan to go with a narrower 15, like a 6" or 7" wide plain steel wheel, you should probably use drop springs to avoid clearance issues. You will lose suspension travel, though, and be limited to narrow tires if you do.
Slonaker
EDIT: Yeah, what he said...
Stock '01 Silverado
Old 08-23-2006, 02:18 PM   #11
75Chevy90Kawi
the green machine
8" and 10" would avoid clearance problems you think?
2003 Suzuki TL1000R
My pictures
Old 08-23-2006, 02:27 PM   #12
Slonaker
Slonaker's Avatar
They will with Rally wheels or something with the same offset. The 10" rallys are available aftermarket only, but they were available in 6,7, and 8 inch widths factory (I think).
Slonaker
EDIT: This is all assuming you have the 2.5 inch spindles. I am told that the 3" spindles will clear 8" Rallys with some grinding onthe caliper and/or the lower control arm.
When you know what wheels you want, ask around here and see if anyone is running that particular combo so you will know for sure.
Stock '01 Silverado
Old 08-23-2006, 02:40 PM   #13
boxrodz
boxrodz's Avatar
The advantage of aftermarket rallys, is your selections of backspacing. With the proper bs (~5") on a 10" rally, you shouldn't have any clearance problems in the rear. Up front, I'd think you need around a 5" bs on a 8" rally to clear the fender lip.
boxRODz
Old 08-23-2006, 02:44 PM   #14
75Chevy90Kawi
the green machine
does anyone know about what the backspacing is on the stock wheels?
2003 Suzuki TL1000R
My pictures
Old 08-23-2006, 02:55 PM   #15
boxrodz
boxrodz's Avatar
I believe the stock 15x8s have a 4 1/4" bs.
boxRODz
Old 08-23-2006, 08:37 PM   #16
75Chevy90Kawi
the green machine
so some 15" smoothies or rallys with 5" backspacing and an 8" in front and 10" in rear huh? and a 5 lug 5" bolt pattern right?
does anyone have any specific wheels they really like that would fit this bill? i've been lookin on summit for a few, and this is the only one i can find that fits these #'s
http://store.summitracing.com/partde...5&autoview=sku
what say you?
2003 Suzuki TL1000R
My pictures
Old 08-24-2006, 08:51 AM   #17
Slonaker
Slonaker's Avatar
Ny neighbor has those on an El Camino with those caps, and they look really good.
Slonaker
Stock '01 Silverado
Old 08-24-2006, 02:12 PM   #18
75Chevy90Kawi
the green machine
it's a 5" bolt pattern right?
2003 Suzuki TL1000R
My pictures
Old 08-24-2006, 02:42 PM   #19
Slonaker
Slonaker's Avatar
I think the El Camino uses a different bolt pattern, but the wheel is available in several different bolt patterns from wheel vintiques. Stckton wheel and other probably have them as well.
I think bigblock73 has those on his truck. You might ask him about them, and what parts he used to lower it.
Slonaker
Stock '01 Silverado
Old 08-24-2006, 02:49 PM   #20
75Chevy90Kawi
the green machine
i went onto the wheels vintiques website and it looks like i can fit the 33 or 37 series wheels in a 15x10 and a 15x8... i'm leaning towards the 37
http://wheelvintiques.com/shopsite_sc/store/html/page25.html
http://wheelvintiques.com/shopsite_sc/store/html/page35.html
:note, i can get all the different caps for those wheels, not just those shown
or i can get smoothies if i step up to 16x10 and 16x8
http://wheelvintiques.com/shopsite_sc/store/html/page7.html
http://wheelvintiques.com/shopsite_sc/store/html/page15.html
2003 Suzuki TL1000R
My pictures
Old 08-24-2006, 03:13 PM   #21
C-10volvo
C-10volvo's Avatar
i got my rallys at the local les schwab for about 50 bucks a pop. they are 5 on 5 however, they are only a 15X6 inch wheel. i put them on when i was 16 and did not really know what i was doing.... i know they come in 15x6, 8'' and 10''
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 08-26-2006, 01:47 AM   #22
boxrodz
boxrodz's Avatar
75Chevy90Kawi-
If you can get a picture of your truck taken at the same angle like that of the wheels you linked, we can p'chopped them on your truck. If you go with 16s make sure the tire sizes you want to go with are available. 16s don't come in as many sizes as the 15s. But, I think 16s may look better in the fenderwell if you end up choosing a lower series sidewall. IMO, the 60 series tires on 15s (like 235/60/15s) sitting under the front of truck (like in the pic of the blazer) look a bit small. 16s may help that.
Just a thought... The chopped and lowered satin black truck is smashingchuck's and it's wearing 17" smoothies. But, I can't remember who sells them.
boxRODz
Old 08-26-2006, 03:38 PM   #23
Low84
Low84's Avatar
What are the stock dimensions of the truck rallies like Slonakers. 15x6? 15x7? and whats the backspacing?
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 08-26-2006, 03:52 PM   #24
75Chevy90Kawi
the green machine
hhmm... well first off, that color on the smoothie (green) looks AWESOME! second, that slammed truck with smoothies, well, i wanted more sidewall than that. that's why i'm getting new wheels, is because i want more rubber and less chrome. i'll try to get a pic soon though.
2003 Suzuki TL1000R
My pictures
Old 08-26-2006, 04:16 PM   #25
stepside454
stepside454's Avatar
Heres mine last year
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
