72 cab on mid 70's frame
What would have to be done to put a 67-72 cab on a mid 70's frame? Any info is appriciated.
Oilfield Trash
Re: 72 cab on mid 70's frame
I looked into it once, it's way different, if it is done on a 4x4, it will look decent but not a 2wd
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
its all about the +6 inches
the 67 - 72 frame is flat, the 73 - 87 is not. You'll have to doa custom body lift to level out the body. And if you run a bed, you'll have to reloate the rear axle too.
I know the front suspension will bolt in. What about the rear leafs? If I use the front and rear hangers do you think it will work? I would prefer the leafs over coils because this truck will do alot of towing.
What kind of towing? The coil set up is a VERY good setup.
3500lb car plus the trailer and all the spares. Is there anything you can do to the coil setup to make it tow better? I use to have a 67 and was not mpressed with the way it towed. Would rebuilding the suspension help that much?
the only coil truck i had towed like crap, but it was a 500,000 mile crap box with bushings that were practicly non-existant.
When i asked about it, about 25 ppl jumped on my thread saying there's tows like a dream. |
There is a difference between light and heavy duty coils. I expect the light duty coils would squat more, but the biggest difference to me would be bushings on the rear control arms, the panhard bar, or whatever the centering rod is called, tires and shocks. The front end also has to be good. If any of those components is is worn or not heavy duty, it might well tow like crap. The springs only affect the squat.
jku Cornville, Maine 68 C10 burb 42 Willys MB 46 Dodge WF-32 1.5 ton 53 & 56 Olds' 60 Cadillac 22 Dodge Brothers |
Thanks for the input.
