Old 08-21-2006, 09:35 PM   #1
msgross
msgross's Avatar
Engine Code please help V0405XX
Can someone help to verify this engine code. I find it to be a 69 350 found in K-20 and 30's. That will be dissapointing since I have a 68 K-10 that is tagged to have a 327. That would explain the 4bbl Quadrajet that was on it too. Any thoughts, good bad if its true? thanks...
msgross is offline   Reply With Quote
Old 08-21-2006, 10:20 PM   #2
msgross
msgross's Avatar
Re: Engine Code please help V0405XX
anyone an engine guru?
Old 08-21-2006, 10:38 PM   #3
RSRXION
RSRXION's Avatar
Is this the complete code from the pad just in front of the passenger side cylinder head ? That's what we need. I'll be able to help if you can get the alpha code and the vin sequence from this location. Thanks, Dean
"They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Ben Franklin
RSRXION is offline   Reply With Quote
Old 08-21-2006, 10:40 PM   #4
msgross
msgross's Avatar
that's the only code on the pad...
Old 08-21-2006, 10:42 PM   #5
RSRXION
RSRXION's Avatar
OK , found it. XX is the correct code for a 69 C-10,20,30 or P-20,30 with 4 barrel carb. Listed as medium duty. That's the only application that my original GM manuals list for that alpha code. Hope that helps, Dean
Old 08-21-2006, 10:51 PM   #6
msgross
msgross's Avatar
oops, just checked (and rubbed a little dirt off) It's YX not XX. That's a 67 327 which would be correct for a 68 truck. thanks for the help...what's does your book have on that one?
Old 08-21-2006, 11:44 PM   #7
RSRXION
RSRXION's Avatar
67 or 68 327 with manual trans ONLY and ONLY on the K-10 and 20. Hope this helps, Dean
Old 08-22-2006, 07:06 AM   #8
msgross
msgross's Avatar
cool, that's mine 4 speed manual K-10
Old 08-22-2006, 07:39 AM   #9
RSRXION
RSRXION's Avatar
There's usually a partial VIN there as well. It will contain the last 8 or 9 numbers of your VIN and it will be stamped on that same pad. If you can find it you'll know that it's probably your original engine. People have been known to deck the block and restamp these numbers on high dollar show cars. It isn't right but they do it. Dean
Old 08-22-2006, 06:15 PM   #10
msgross
msgross's Avatar
thanks for the info...I think that this is original, everything else on the truck was and it was a one owner.
