anyone know how hard it would be to retro fit a 95 camaro disc rear into my 71 ?
later lance ![]() |
Re: 95 camaro rear end ??
Just cut the camaro mounting stuff off, buy the correct pads for your application and weld them on, making sure of the pinion angle. You may have fun finding brake lines to fit (go to ss brake lines and have them custom made) cause the Camaro will have metric fittings. I was going to go with a Caprice rear, cause they have discs and the same bolt pattern as the 5 lug trucks. Good luck.
its all about the +6 inches
if you are just doing it for the disks, why not just convert your truck parts to disk instead of degrading your rear axle?
Disks won't help you much onless you are always hauling a butt load of weight, or in the mud. |
those axles are pretty weak so dont plan on puttin any power to them
#5 | |
keep the axle! Do you have discs up front? Cause that is all you need 4 real.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
there is plenty of rear disc kits for your truck without changing the entire rear end.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
You don't want that rear. It's only a 7.5" 10 bolt. They're really easy to break.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop 70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress |
Straight jacket required
I kept my 12 bolt-threw in an Eaton posi and incorporated '95 Caprice 9C1 disc brakes on mine. Better to have a strong rear IMO. You just come up with a bracket to hold the calipers on. There is a thread by 383Stroker here somewhere with dimensions on the bracket-that's what i used. I'll try to find the link.
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
