Old 08-23-2006, 10:10 AM   #1
stingray72
Red Headed Step Child
stingray72's Avatar
Gas tank swap
Ok, this has probably been covered but most of the threads I've found are for the filler locations and quite frankly I haven't gotten there yet.
Anyways.. I started cuttong off the spare tire crossmember last night and tried to test fit my tank (blazer tank from ****************). I noticed there are a few things that I don't know what they are? I've attached a stick drawing looking towards the front of the truck as if I were standing over the tank.
I've got a pretty good grasp on the filler neck and the sending unit hole but there is a couple of other openings I don't know what they're for. I assume maybe a vent or something
There's about a 1" neck next to teh filler neck.
and there are (2) 1/4" or so necks at the corner of the tank (top left and top right)
What are these for? (and forgive my crude drawing)
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 08-23-2006, 05:12 PM   #2
stingray72
stingray72's Avatar
Re: Gas tank swap
ttt
-Homer Simpson
Old 08-23-2006, 06:41 PM   #3
Rdub
Re: Gas tank swap
Try a search on tank.... within the last 2-4 months this exact same subject was discussed and there was a drawing similar to yours which identified every part on the tank and what it connects to, or at least what it connected to on that persons truck.
Rdub is offline   Reply With Quote
Old 08-23-2006, 08:41 PM   #4
bigdog69
bigdog69's Avatar
Re: Gas tank swap
Those two small nipples go to the carbon canister up front.
bigdog69 is offline   Reply With Quote
Old 08-23-2006, 10:32 PM   #5
wibilly
wibilly's Avatar
Re: Gas tank swap
the 1"one by the filler tube is the vent for the filler tube it will attach to the top of your filler tube just below the cap to allow air to escape while filling
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 08-24-2006, 02:31 PM   #6
stingray72
stingray72's Avatar
Re: Gas tank swap
Is the carbon cannister necessary? What is it's function and can I put on along the frame rail or something? Can I cap those nipples?
-Homer Simpson
Old 08-24-2006, 02:59 PM   #7
project1971
project1971's Avatar
Re: Gas tank swap
i am not running a carbon can myself and just made those vents. My filler neck is almost 90 degrees as it comes out in the corner of the bed and it fills better with those as vents then when closed off.
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 08-24-2006, 08:29 PM   #8
stingray72
stingray72's Avatar
Re: Gas tank swap
Okay then.. On to my next question. This tank sits up higher than the frame rails. What are you guys doing to get the bed to clear? Do I have to cut that cross piece on the bed?
If I had known it would be this much of a PITA I would have just fixed the tank in the cab
-Homer Simpson
Old 08-25-2006, 01:13 AM   #9
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: Gas tank swap
I had to trim the cross member in order for my poly tank to fit.
low'n slow is offline   Reply With Quote
Old 08-25-2006, 09:05 AM   #10
Chris4x4Gill2
Re: Gas tank swap
any idea where that thread might be? I have searched and havent been able to find it
Chris4x4Gill2 is offline   Reply With Quote
Old 08-25-2006, 09:57 AM   #11
John Fabris
TOTY 2006
John Fabris's Avatar
Re: Gas tank swap
You do have to trim the crossmember for the bed to allow the tank to fit. As for the tank, if you are not using the charcoal canister, you can close up the ports that you will not be using. You only need the fill one and the one right next to it for your air vent.
Here is a link to the blazer tank install in FAQ
http://67-72chevytrucks.com/vboard/s...ad.php?t=74876
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-25-2006, 12:30 PM   #12
Rdub
Re: Gas tank swap
I don't know how to do a link but, did a search on "tank openings" & found the thread.... I was wrong about the drawing, actually it's a photo of a tank with all the fittings from the top of the tank labled .... try "rear gas tank install help!!!" by cwilkie on 6/21/06
Old 08-25-2006, 06:02 PM   #13
wibilly
wibilly's Avatar
Re: Gas tank swap
when i cut my bed support for clearance i discovered that the wood floor suports slip inside the steele suports nicly. i welded them inside to bux mine where it was clearanced to regain the strength i lost by cutting for clearance of sending unit and filler tube
