Old 08-23-2006, 12:08 PM   #1
jdmaffeo
jdmaffeo's Avatar
Which brand??
I have read a ton of posts on the different drops that are here on the forum. I am planning a 4/6 static drop on my 84 stepside. I am thinking that a drop spindle and spring setup in the front and a flip kit and c-notch in the rear will give me what I want. I might have to do the hangers or shackles to get the 6 inch drop in the rear. I am currently running 15's Centerlines and I don't want to have any interference with the spindles.
1. So which brand spindle and springs should i get?
2. I have seen different designs with the c-notches. Some are semi-circular and some are angular. Is there any advantage of one over the other? If so which brand is the best? I would like to bolt it up and then weld it up later as I don't have a welder easily accessible.
I know what some will say.....bag it. I think that it would look good, but I don't want to mess with it right now. Plus, the parts that I am getting will hopefully still be able to be used if in the future I bag it.
1984 Chevy Stepside, 4spd granny, 4 1/2 front/6 inch rear drop.
jdmaffeo is offline   Reply With Quote
Old 08-23-2006, 01:18 PM   #2
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Re: Which brand??
Get Belltech or McGaughyes (<not sure how you spell that). I have belltechs. The only thing you will be able to use when you bag it are the spindles. As far as the c-notches go, i wouldnt think it would matter the shape except the rectanguler one may have a little more room for clearance. If you could get your hands on a welder for a day then you could just take some 5" pipe, cut it in half, notch the frame, and weld it in. That would save you a few bucks. Good luck.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
