Old 08-23-2006, 05:37 PM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Trailing Arm Cross Member
I see that CPP now has a trailing arm cross member. If you look at it, it appears that they have moved the mounting holes for the trailing arms higher in the mount. I assume that this is what they call " correcting the pinion angle in lowered trucks " Is this enough difference from the one from ECE to really have any effect ?
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-23-2006, 10:32 PM   #2
SCOTI
SCOTI's Avatar
Re: Trailing Arm Cross Member
Nope.
They are basically the same thing (ECE vs. CCP). The trailing arm brackets 'bolt-on' to the crossmember. You simply unbolt them & flip them side to side to relocate the mounting position higher.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-24-2006, 07:30 PM   #3
XXL
Seņor Member
XXL's Avatar
Originally Posted by SCOTI View Post
Nope.
I believe they're welded in place on the CPP unit.
XXL is offline   Reply With Quote
Old 08-30-2006, 03:44 AM   #4
thekid54
Yep, they are welded in place on the CPP one. Flipping the mounts screws you over if you want to go lower then 4-5" in the rear. With the higher mounting point the trailing arms hit the frame rails much sooner, not allowing you to go low enough. That's why I will be selling mine!!!
thekid54 is offline   Reply With Quote
