Old 08-23-2006, 06:53 PM   #1
pontiac6269
pontiac6269's Avatar
Non Chevy engines in Chevy trucks.
I have a 81 3/4 ton 2 w/d that I'm putting a Pontiac 400 in. The 350 has a main bearing rattle. Are 3/4 ton mounts in the same position as a 1/2 ton? I had to use the lower mounting holes on the mount plates, also had to move the plates back 1 inch on the drivers side and 1 1/2 inches on the passenger side. Then drill holes in the frame and crossmember. I've read where others have done this swap in 1/2 tons and just had to move the frame mounts up to the upper holes. I'm using the original turbo 400 with a TCI adapter plate so the trans is mounted in the original location. Has anyone else done any kind of swaps like this or other engine familys?
Thanks,
Eric
pontiac6269 is offline   Reply With Quote
Old 08-24-2006, 06:28 AM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: Non Chevy engines in Chevy trucks.
As far as i know all the crossmembers for the 1/2, 3/4, & 1 ton trucks are the same as far as the engine mount locations go the only thing thats differant is weather it has a big or small block thats what the other set of holes are there for.
Now the only thing i can think of is maybe the crossmember is differant for the diesel equipt trucks???
Maybe you misunderstood what you read or that person didn't explain what or how he did it clear enough.
I haven't seen any 73-87 chevy trucks with anything other than a chevy BBC or SBC engine in them.
Good luck
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 08-24-2006, 08:43 AM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I drove a 70s 1/2 ton about 20 years ago that had a Pontic 400. The owner told me he used mounts out of the donor car (I can't remember what it was), and it was a direct bolt-in. I wish I could remember more details...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-24-2006, 12:46 PM   #4
cliffsta
Stepsides RULE
cliffsta's Avatar
So you said you had the adapter plate for bolting up BOP to the Chevy uh, (is it the flexplate?)
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 08-24-2006, 12:49 PM   #5
Joe67
67 is sold
My buddy puts BBC motors in Mustangs, anything is possible
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-25-2006, 07:14 AM   #6
87 STEPPER
87 STEPPER's Avatar
Thumbs up Re: Non Chevy engines in Chevy trucks.
It's funny after i say i haven't seen any of these trucks with anything other than a chevy engine in them i pick up an issue of classic trucks at wall mart yesterday and in the back is the readers rides and there is a 70's stepside with a 500ci caddy engine in it
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 08-25-2006, 05:24 PM   #7
pontiac6269
I had it mocked up in the truck with a bare block and original transmission. The adapter plate adapts the Chevy transmission bell housing to a BOP engine. The block mounts to use are out of a 73-77 Lemans or Grand Prix.
Thanks,
Eric
Old 08-25-2006, 05:43 PM   #8
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Some of our trucks came with Olds motors in them stock (in the way of 5.7L diesels), so I couldn't see that it would be too much trouble swapping in a BOP engine.
ARAMP1 is offline   Reply With Quote
Old 08-26-2006, 12:11 PM   #9
WLPTMP
Active Member
WLPTMP's Avatar
on the 73-87 i'm putting a caddy 500 in
the only thing i have to move is the fram side of the motor mounts about 2 inches forward and trim the coners if you are using stock steering
WLPTMP is offline   Reply With Quote
Old 08-27-2006, 08:53 PM   #10
pontiac6269
I have the engine and trans bolted down. Starter is on and wired, routing fuel lines. Got a set of 3 tube headers from a friend that actually fit, just have to bend shift linkage.
