Old 08-23-2006, 08:48 PM   #1
byrd
Union Electrician
byrd's Avatar
short or long water pump?
Is there a way to tell if the heads are correct for a short pump set up. The motor I got with a parts truck has a long pump on it now,but I would prefer it to be a short pump setup to look a little cleaner ,plus I have almost everything needed for a shorty.It does have some tapped holes in the heads close to where the alt bracket would bolt up. Any help would be greatly appreciated. Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 08-23-2006, 10:13 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: short or long water pump?
The heads were drilled in 69, and remained drilled the same way untill the 90's when the vortec heads came onto the scene, then they deleted a hole. The trucks retained the short pump till the end of 72, and vette's did for some time after that.
basicly, it doesn't matter. If you have old heads with holes, you can go short or long.
Old 08-23-2006, 10:14 PM   #3
junkyardjohn
junkyardjohn's Avatar
RANDY... I BELIEVE THE HEADS ARE ALL THE SAME ON PRE 86 350s AS FAR AS SHORT OR LONG WATER PUMPS GO. THE DIFFERRENCE IS IN THE BRACKETS & PULLYS. THE ONLY HEADS I CAN THINK OF WITHOUT ACCESSORY ARE THE 327 HEADS. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-23-2006, 10:36 PM   #4
byrd
Union Electrician
byrd's Avatar
Thanks, Andy and John for the quick help.
Zip:40272
Old 08-24-2006, 10:41 AM   #5
Huck
Huck's Avatar
Randy--Andy & John are right on---should be ok. If you run into issues, call me as I have some brackets from both long and short setups. We will make it work out--no biggie. Now if you really wanted cool--serpentine belt setup--hehehehe
Huck is offline   Reply With Quote
