Old 08-10-2002, 02:23 PM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
water pump plug
can anyone exsplain the bypass thing in a water pump. new water pumps come with a metal dowl thing to plug the bypass.. i never have used the thing.. whats the deal
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 08-10-2002, 02:29 PM   #2
Zkast
Zkast's Avatar
Metal dowl? If its a basic GM long pump, they come with a NPT pipe plug to block off the heater return if the vehicle is equipt with a radiator heater return. I've found the systems with a waterpump heater return are more effecient and heat the coolant faster than the style that use the radiator as the heater return.
Zkast is offline   Reply With Quote
Old 08-10-2002, 02:47 PM   #3
jostrans68
Jostrans68
jostrans68's Avatar
some corvettes had a bypass tio the intake
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 08-11-2002, 12:25 AM   #4
mtdave2
mtdave2's Avatar
YA A METAL DOWL THING.. PIECE OF ROD METAL, ABOUT 1 1/2 INCHES LONG, 1/4 INCH WIDE. THIS HAS CONFUSED THE HELL OUT OF ME FOR YEARS. IM NOT TALKING ABOUT THE PIPE PLUG.
69 k10 Suburban
Old 08-11-2002, 10:45 AM   #5
Zkast
Zkast's Avatar
Hmmm doesn't sound familiar...
Can you take a pic of it so we can see what your talking about?
Generally most GM aftermarket or new pumps come with a Clamp, Pipe plug and gaskets. Occasionally they will supply you with the 4 studs and sealer.
Old 08-11-2002, 08:16 PM   #6
THOR 50
Over worked under paid
THOR 50's Avatar
Question possible idea more info.
does it have a slot in the top for a flat head screw driver?
Roger
'69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears
THOR 50 is offline   Reply With Quote
Old 03-29-2003, 07:41 PM   #7
jmil1974
Ain't we cute?
jmil1974's Avatar
I've got one of these too. I'll see if I can get a pic.
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES!
FOR SALE $3900
jmil1974 is offline   Reply With Quote
