08-23-2006, 11:03 PM | #1 |
did 292 c10's get 4:11's? std
Seems like I read somewhere that 292 half tons got 4:11's std. Is that so? My old orig 67 has the glove box door sheet torn off. Is there anything else the 292 motor truck got that the 250 didn't standard?
08-24-2006, 12:51 AM | #2 |
Re: did 292 c10's get 4:11's? std
My 70 c10 w/292 came with 4.10's , can't say for others .
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
08-24-2006, 12:56 AM | #3 |
My '68 C/10 stepside came w/292, SM465 and 3.73:1 12-bolt open differential. Also 7.00 x 17.5" tires specified on the glove box door.
08-24-2006, 06:27 AM | #4 |
You won`t find gear ratios on the VIN-spec sheet.I believe the I6/manual combos came through w/4.11s unless another ratio was specified,up or down.Everything else would be the same on a truck whether it had a 250 or 292.Only pieces that were required for that particular engine would be different,like motor mounts,etc.
08-24-2006, 09:30 AM | #5 |
My 250 with 3spd manual came stock with 4.56 gears, its not an option listed on the build sheet (of which there were only 4, so I figured that was just what all I6's came with)
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
08-24-2006, 03:13 PM | #6 |
its all about the +6 inches
Shelby, yours is a 3/4 ton, so the standard gears is a 4.56.
My books show 3.73 being standard with both inline engines. *standard includes 3 speed transmision, when you get other trannys, other gears become standard with that engine/tranny combo* Last edited by Longhorn Man; 08-24-2006 at 03:14 PM. |
08-25-2006, 12:27 AM | #7 |
My 68 C10 Burban came 4spd 292 w/ 3.73
